Dampness in Garage
Tafarelli
Dampness in Garage
Post by Tafarelli »
I have a single brick garage which is extremely damp inside. Anything I keep in there get covered in mould. There appears to be a damp proof course at the bottom of the garage but one wall in particular is very wet.
Can anyone suggest what I should do to dry it out and what I should treat the walls with etc.
Any help would be appreciated.
theplasterersarms
Been thanked: 1 time
Post by theplasterersarms »
check for roof leaks ,also take a look at the brick pointing....keeping the door open as much as possible will help to dry it out
good luck
Steve
[url=http://www.authenticplasterfx.com/][color=red]Authentic Decorative Lime Plastering[/color][/url]
