Toilet under tiles
Posted: Thu May 07, 2009 3:43 pm
by hooly
I want to take the toilet up, and tile under, Plumbing know how = zero
Posted: Thu May 07, 2009 3:44 pm
by hooly
Can i get a flexible bit, as the toilet will lift quite a bit higher?
Posted: Thu May 07, 2009 5:44 pm
by thescruff
You should be able to use what you already.
Note the extension piece isn't fully inserted, it looks as though its pulled out.
Posted: Fri May 08, 2009 4:38 am
by m3 fitter
if not use a jollyflex pan connector from the original svp and then connect your existing 90 to the end, to be safe, available from most diy stores and here:
http://www.toolstation.com/shop/Plumbin ... 887/p65378
Posted: Fri May 08, 2009 4:37 pm
by hooly
thescruff wrote:You should be able to use what you already.
Just checked, its in tight, wont go no more, at the limit
cheers both
Posted: Fri May 08, 2009 5:18 pm
by thescruff
There's nearly three fins sticking out which shouldn't be, try twisting and pushing at the same time.
How much are you looking to raise the pan.
If you go for the jollyflex pan connector ( I would use whats there) get the bent type so you only need one fitting.
Posted: Fri May 08, 2009 6:56 pm
by hooly
12 mill ply, 8 mill tile, and the say 5 mill of adhesive..approx
will try when i go back upstairs
Posted: Fri May 08, 2009 7:15 pm
by thescruff
Are you keeping the existing suite, the outlet height varies quite a bit.
Looking at the pic, so it's not clear, but I would go for a plastic socket on the existing pipe with a short length of pipe and a 112% bend into a bent pan connector, that would give you around 25-30mm
Posted: Wed May 13, 2009 4:16 pm
by hooly
I think the right side pipe is too far in the middle bit, hense that not fitting right, cheers
I have a idea what i now need when its raised
