Main equipotential bonding
I am in the process of installing a new consumer unit, which is loacted in the garage and will be connecting the gas pipe to it with 10mm2 main equipotential bonding cable. My problem is that the entry point for mains water into the house is in the kitchen, which is some distance away to the consumer unit. Can someone please advise me if I have to run a 10mm2 bonding lead from the mains pipe in the kitchen back to the consumer unit, ignore this connection or is there a another method. Thanks.
