My first post on this forum so just want to say hello
I’m half way through renovating my first house. It’s a 1950’s semi. I have worked my way around a lot of it but I’m a bit stuck on cavity closure around the windows. It still has the (as far as I can see) older style cavity closers which is basically mortar and slate. I have a friend who lives in same house on the road and all his walls around windows are constantly damp and black so I think now would be a good time to sort it out properly. However, I can’t find any cavity closers that will fit the gap (it’s around 30-40mm at the moment and very uneven) as half the cavity has been closed by brick from the inner wall. Photos below:
Is it worth cutting the brick back to open it up fully and fit a proper cavity closer or can I remove the slate and pack it full of foam? Any other suggestions would be great
