penatrating damp
couchie
Has thanked: 23 times
penatrating damp
Post by couchie »
Hi
We have a very damp exterior wall. Im sure the problem is penatrating damp. Its an old house, solid stone walls, The outside ground is about 4' up from floor level, I intend to dig a trench outside, put a perforated pipe down, fix a membrane on the wall & then backfill.
Is this the right thing to do & what would you recomend I use as a membrane.
Thanks. Chris
Deleted-user-3
Has thanked: 101 times
Been thanked: 157 times
Post by Deleted-user-3 »
These users thanked the author Deleted-user-3 for the post:
couchie
couchie
Post by couchie »
Thanks for that, great help. Not just about the products but also some reasurance that im going the right way about it.
Cheers, Couchie.
