Help with connecting my dimmer switch
Hi there,
I hope someone out there can help me.
I thought I would install a dimmer switch in my daughter's bedroom as I have just finished of decorating it and that would finish it of.
I assumed wiring a dimmer switch would be straight forward even for a novice like me, just follow the wires no problem.
I bought a dimmer switch from homebase and was ready to go.
When I unscrewed the light switch from the wall and seen all the wires I just gave up.
The house is around 30 years old and the electrics are in good condition as I was informed by a spark whom I trust.
This is what is inside the box behind the lightswitch.
Firstly there are 3 grey cables in each of these cables there is a red live and a black neutral wires.There are also the 3 green/yellow wires that that come from the bottom of the box and feed into each of the 3 grey cables.
2 of the red wires are connected to the available screw at the top on the back of the existing light switch and the other is screwed into the bottom of it.
The 3 black wires are capped and do not connect to anything.
I have looked at the back of other light sockets and they are all the same
What I'm not sure of is which of the 3 red wires go into the com and L1 on my dimmer switch ?
I hope my explanation is understood as I lack of electrical description.
Many Thanks
Many Thanks
