ant67
sorry should say use the chimney with a linerant67 wrote:hi all this is my first post .im doing up my 1920s home ,taking foreverive got a damp spot in the bedroom where the chimney is,ive looked over the roof had the lead flashing replaced,and the damp is still there,ive put on a cowl thats not helped,forgot to say we still use the chimney with a flue any help would be great thanks
ant67
thescruff
ant67
thescruff
stuart45
ant67
thats why i had the roof sorted and the lead flashing done,can you get a diy kit for this ,if it is this ,is there anyway of fixing the problemstuart45 wrote:The plaster on chimneys often contains hygroscopic salts which attract condensation at a R/H as low as 50%. This problem often confuses the roofers who think that it is a leak. You can have the plaster tested for these salts. If it contains them replaster with sand/cement/salt retarder.
ant67
thescruff
stuart45
ant67
