Metal workers, Engineers - help and I'll pay
horseguards
Post by horseguards »
Maybe someone can help me with this - I will pay for it.
Please refer to the picture below.
There are two options to consider:
1) To cut out identical notches on the front and right
2) To make/cut a piece of steel (8" x 3" x 1/4" or 200mm x 75mm x 5mm), again with notches cut out on all sides.
Any offers or when it can be done will be greatly appreciated.
Grant.
Square notched tiling trowel.jpg (23.69 KiB) Viewed 2479 times
mikew1972
Has thanked: 11 times
Been thanked: 110 times
Post by mikew1972 »
Is it because you are left handed? I'm sure left handed ones must be available.
Going to be a lot of work without the right tools. I'd consider buying 2 trowels, separate the handles from the bases, cut em in half corner to corner and weld the 2 halfs togeather to give notches all round then reattach the handle.
Lot of work though and I'm not offering to do it, just suggesting a way to do it.
If the notches don't have to be EXACT then just attack it with an angle grinder?
Mike
horseguards
Mike,
That's a clever solution but beyond my talents and resources.
Left-handed notched trowels are available (Marshalltown).
I am right-handed and would prefer to work left-to-right on the front stroke, right-to-left on the out-of-right reach return/backstroke (if you see what I mean) when spreading for tiles on a wall.
This may just be a symptom of being new to tiling but it seems that to work both ways is awkward - if not impossible. Think of plastering - you can go left-to-right, right-to-left, up-to-down, down-to-up; makes no difference in terms of ease. My suggestion would allow this.
Maybe I should get out more.
Grant.
Hitch
Has thanked: 77 times
Been thanked: 335 times
Post by Hitch »
5mm seems a bit thick?? bit of 1.5/2mm stainless would be alright wouldn't it?
Are they some sort of hardened steel?
Adapt a bought one...
Use an angle grinder and cutting disc to cut a series of slots, then just tidy up with a file. :thumbright:
horseguards
Hitch,
The Marshalltown finishing trowels are 1mm thick and made of stainless steel.
I specified 5mm for the simple reason a 1mm will wear-out before a 5mm. Marshalltown's (and all their imitators) 1mm is probably their built-in obsolescence, ie a very limited life span then you have to buy another. Same with cars - hasn't the reputation for reliability of Merc's taken a dive over the last few years?
I could try and adapt a new one but would probably screw-up (metalwork was not my best subject at school).
Grant.
