I have just replaced a light fitting in my hall which was a Pendant Set which was fairly straight forward to connect. I am trying to put up a 2 Bar Spotlight but unfortunately there does'nt seem to be enough connections for the wires I have. There r 3 sets of wires coming from the ceiling..3 live, 1 neutral and 2 earth but on the Spotlight (photo attached) there are only 2 connections Live and Neutral plus there is a screw in connection for the Earth.
I have wired the connections (1 Live and 1 Neutral have been connected) as per instructions but unfortunately the light switches on but wo'nt switch of. Any advice on whats going wrong, Also were are the other 2 Live Wires to go. I have tried connecting them to Live connection along with the Live wire that I get a constant light on but no difference.
Hope the above is clearly described and any advice would be helpful
Dell.bhoy
