diesel pre heater fault
bgatty68
Has thanked: 21 times
Been thanked: 5 times
Post by bgatty68 »
had a light warning come up on the dashboard of my SEAT LEON 1.9TDi and after looking in manual found out it is "diesel pre-heater" now what exactly is that and what do i need to do? i know absolutly nowt about car engines :cb
thescruff
Has thanked: 360 times
Been thanked: 3735 times
Post by thescruff »
It makes it easier to start in cold weather.
Turn the key and wait a while and it should go out, then you can start her up. :lol:
bgatty68
Post by bgatty68 »
cheers thescruff
will try it and let you know :wink:
Has thanked: 833 times
Been thanked: 3636 times
The glow plugs help for cold weather starting. When one of them is dodgy it will put a warning light on. You may need to get the plugs checked.
Has thanked: 1012 times
Been thanked: 918 times
Post by ultimatehandyman »
I changed a set of glow plugs on my Vauxhall Combo van a few years back. I can't remember it being difficult and they were only a few quid each.
Hitch
Has thanked: 77 times
Been thanked: 335 times
Post by Hitch »
Usually an easy job for someone with some common and a a decent tool kit.
Can be a bit fiddly getting to them on some engines though.
Replace the set, not just one. Probably about £25 for a set
Sparky James
Has thanked: 8 times
Been thanked: 76 times
Post by Sparky James »
Is the light flashing while you drive or does it just come on before you start the engine?
If the latter its normal
If the former then some VAG cars and vans use the preheater light "flashing" as a engine management fault warning light. If so you need to have the ecu scanned for the fault.
Good luck
bgatty68
Post by bgatty68 »
sparky james
it comes on while im driving
how much am i looking at to get the ecu checked :scratch:
