2Ton Jack Problem
kintangoman
Has thanked: 83 times
Been thanked: 24 times
2Ton Jack Problem
Post by kintangoman »
Tried to change the brake disc in my car 2day (MOT due in 5days), but the 2ton jack only lifted a little bit, then would not raise car any further. looks like the hydraulic function wont work. any advice??? :scratch:
thanks.
kintangoman
thescruff
Has thanked: 360 times
Been thanked: 3735 times
Post by thescruff »
Buy a new one :roll:
Sparky James
Has thanked: 8 times
Been thanked: 76 times
Post by Sparky James »
top it up with jack oil
kintangoman
thescruff wrote:Buy a new one :roll:
ok scruff, but i think i'll go with sparky james and top-up with jack oil (if i can find one). if that fails, then i,ll get a new one. :shock:
darrenba
Has thanked: 104 times
Been thanked: 490 times
Post by darrenba »
Also make sure the release valve is fully closed.
Simon Site Manager
Has thanked: 48 times
Been thanked: 202 times
Post by Simon Site Manager »
I reckon the seals have gone!
S
kintangoman
Simon Site Manager wrote:I reckon the seals have gone!
S
the release valve is fully closed. made 3 attempt at lifting car & relerasing jack 2B sure. have had jack now for 7yrs, so may be the seals have had it???
will still locate and add jack oil then see if it helps. if it doesn't, then i'll buy another. :cb
kintangoman
Hitch
Has thanked: 77 times
Been thanked: 335 times
Post by Hitch »
Sounds like it just needs a drop of oil.
kintangoman
Hitch wrote:Sounds like it just needs a drop of oil.
I'll be puting some oil in the jack :thumbright:
thanks
kintangoman
