Help! Water leaks through grout.
Posted: Tue Nov 17, 2009 10:09 am
by suddenlysummer
Dear All,
We had our bathroom tiled recently. Yesterday I found that water is leaking through the grout between a few tiles close to the bath. Can anyone here tell me if I can remove the grout and use sealant between these few tiles? Also what is the best way to remove grouts? Thank you.
Regards,
Summer
Posted: Tue Nov 17, 2009 10:25 am
by chris_h
Posted: Tue Nov 17, 2009 11:03 am
by suddenlysummer
Thank you Chris.
After removing grout, can we use sealant instead of grout to fill the gap between tiles?
Posted: Tue Nov 17, 2009 11:20 am
by skiking
Shoudn't you be fixing the leak rather than sealing the tiles or am I missing something
Posted: Tue Nov 17, 2009 11:25 am
by suddenlysummer
Hi Skiking,
When using shower in the bath, water is leaking through the grout. The grout somehow is not water proof
Posted: Tue Nov 17, 2009 8:08 pm
by Beachcomber
You say you 'had' the bathroom tiled - does this mean you paid someone to do it?
If so drag the toe-rag back round and get them to put it right.
If you do it yourself then use the grout rake (link in chris_h's post) and use a good waterproof grout - sealant will look odd and more than likely discolour / go mouldy in time. Make sure you leave the grout a good 24 hours to dry before getting wet.
Bit odd that a little missing grout is letting is water - whats behind the tiles? Should have a solid bed of adhesive behind the tiles?
Posted: Tue Nov 17, 2009 8:29 pm
by tictic
suddenlysummer wrote:Hi Skiking,
with beachcomber here get the tiler back..
regarding grout it not waterproof it water resistant...
not unless you use an EPOXY GROUT which is WATERPROOF.
Posted: Wed Nov 18, 2009 1:47 pm
by suddenlysummer
Thank you for all you advices.
Saddly two guys did our bathroom have gone with all the money they asked and left us with endless troubles. When I phoned them they promised me to come back but never did. I don't want to upset myself too much by recalling what they did. It's the worst experience.
