Cutting an exsisting kitchen worktop.
Hi, all. I have a little job to do at home. I need to cut down the length of an all ready fitted work top. I need to fit a fridge in the place where the work top sticks out. I assume that I should use my router, however what should I do when I get to the final inches where the router won't cut near the wall? Do I need to use a very fine cut hard toothed saw? If so, anyone any ideas as to which saw would be up to the job.
hiya , i would suggest that you take it in stages , use your router initially and as far as it goes , as you ve already suggested swop over to a fine hand saw to finish taking the bulk out , then swop over to a belt sander or orbital to finish ....then either metal end strip or edge with impact adhesive and matching strip . best of luck.
kk
kk
- Has thanked: 35 times
- Been thanked: 257 times
i had a job like this last week, used a normal beco panel saw but with the teeth uphill, easy 2min job.
if you have a GOOD jigsaw make a guide would work with a blade like http://cgi.ebay.co.uk/DEWALT-DT2074-FLU ... 1537wt_941
i would only use the jigsaw if its a good one,
other option is a multimaster but not many people have them for some reason
