All of the downstairs walls have a kotina polystyrene layer behind the wallpaper and quite a lot of the wallpaper is peeling off (hence being sold at auction).
I've had two damp / building preservation companies look at the property. One said just to replace the old skirting boards that had been subject to damp and then be prepared to decorate more frequently than a new house, the other has suggested injection of a silicon(?) dpc, tanking and rendering the walls up to 1.2m and then skimming over the top. Both companies picked up damp readings but it seemed to be barely going into the red on the meter just above the skirting boards and then green/yellow at about 2 feet up.
There are also signs of quite a bit of weevil around the edges of parkay flooring (that was under carpet) that I've uncovered. The parkay appears to have been laid on concrete flooring with an old bitumin sealant. There is one room downstairs with floorboards and there are no signs of rot in the joists etc.
So I'm very confused and not sure what to do for the best. I am hoping to stay in the property for quite a few years.
I scrapped off a section of the kotina today. Above the skirtings is about 6 inches of sand and cement render and then above that is plaster. Somebody has obviously tried to deal with damp in the past although probably quite a while ago. If I do just replace bits of skirting board, should I have the walls re-skimmed with plaster including over the render, or just use lining paper prior to painting. The plaster above the render seem fairly sound to me, but I'm no expert - it wasn't crumbly and didn't look obviously damp.
Thanks for any advice.
Chris
