blown fuse
tictic
Has thanked: 5 times
Been thanked: 23 times
blown fuse
Post by tictic »
hi all looking for advise
brother has a vauxhall zafira 56 plate
the 10amp fuse for the washers keeps on blowing he has put 3 new fuses in over the last week but keeps blowing.
the fuse box is on the passenger side of the engine (if any help)
again thanks for any help/advise
tictic
Post by tictic »
just called him, lol
he has said he as been getting new 10amps from vauhall dealer.
again cheers.
Has thanked: 1012 times
Been thanked: 918 times
Post by ultimatehandyman »
The first obvious question is that he is not trying to shift snow off the windscreen is he?
That can easily fuse wipers as they are not designed to move snow.
If it is not that, has he checked his manual to ensure that the fuse should be 10 amps?
He could try giving the motor a spray with WD40 in case any moisture is causing a problem.
Mooncat
Has thanked: 81 times
Been thanked: 72 times
Post by Mooncat »
Is anything else on the same circuit? The fault may be elsewhere.
