alternators fine, stick a wire on the terminal and arc it on the engine and it sparks like a good un... run this to the +ve battery terminal and it seems to cure the problem..
question is, whats wrong with it? i thought dodgy wiring but exactly the same problem in two almost identical cars?
relay possibly? how do you check if a relay is knackered? not that i know which one it is anyway?
