Just thought you guys might like the junction box I found
This is where you can post pictures of extremely poor workmanship, whether it is done by a dodgy tradesman or by an incompetent DIY'er. Instructions on how to post pictures can be found in here.
ereitiz
Has thanked: 5 times
Post by ereitiz »
This is exactly how I found this junction under my floor, It did at least have insulation tape on some of it !!
Best bit is (I couldnt get a photo) One side of this led about 3ft to a juntion box and the other way - about 6ft to a similar joint with a piece of "lead covered" cable (which was another 6ft long) to the next socket ---- needless to say there is now a single continious piece of 2.5mm T&E between the relevent sockets !!!
Old Underfloor wiring.JPG (59.68 KiB) Viewed 5235 times
Has thanked: 1012 times
Been thanked: 918 times
Post by ultimatehandyman »
Good find :thumbright:
I have often found things like that under floorboards!
I've also seen much worse :?
Return to “Rogues Gallery”
