Two days ago, the rain, sleet and snow was lashing down and as I decided to put the fan heater on the windscreen. Just to set the scene, the fan has only worked on option 4 for many months now, and when a friend had a look at it to fix it, he wiggled some wires in the process and hey presto, it worked on all options, but then shortly after, it only worked on number 4 again, so I tend to put it on for short blasts and then turn it off as its so noisey on full.
On that wet and cold day, as if by some miracle, it started to work on all the settings, but with such appalling weather the window misted up in no time, so after discovering that it now worked on 1,2 & 3, I put it on full. This is when I started to smell a funny pong. I was worried as it reminded me of the smell of hot brakes. When I put the fan off, the smell went away.
I stopped in a layby and popped the bonnet, lots of steam everywhere, around the radiator mainly, yet there was no smell at all. I checked all the wheels for heat and they were all fine, no sticking brakes.
Yesterday I started the van up a good 10mins before I had to go out to defrost the inside. With the fan on full blast that smell was present again.
So to sum up, the smell is only present when the fan is on, whether I'm driving or stationary, the coolant level is fine and there are no leaks inside from the heater matrix as far as I can see.
At first I assumed it was the clutch, but now I'm not so sure. Do you guys have any suggestions?!
