If I am doing a complete room and the carpet is being trashed, I ask for it to be left in place until I've finished.
All I do is cut the carpet about 5 to 6 inches off the skirting around the room and remove the cutting.
Leaving the carpet down keeps a lot of dust down and soaks up any water or paint spills. It also makes it a bit more comfortable and doesn't echo as much.
Once you've finished remove the carpet (this is for the DIY'rs, I usually leave it for the carpet fitters, but if I do lift it. I roll it up and it takes all your mess with it, not that I'm messy!) and you'll have left a room with virtually nothing on the floor (bar the outer edge).
