Best bits to use?
dipztik
Best bits to use?
Post by dipztik »
Hiya folks, I'm drilling through brass and stainless steel, using 1.5 and 2mm bits, they've been braking, what's the problem? do I need to spend more money on better ones or is my technique crap? :-)
kellys_eye
Has thanked: 357 times
Been thanked: 1790 times
Post by kellys_eye »
Technique!
Are you using a drill press or by hand?
dipztik
Post by dipztik »
Eye eye, :-) by hand, am I pushing down to hard or maybe it's the cheapo bits I'm using? never used such small diameter bits before.
Hitch
Has thanked: 77 times
Been thanked: 335 times
Post by Hitch »
They are pretty small bits to use in a hand drill. They are probably grabbing, and the power of the drill is just twisting them off.
Tricky, you need good pressure, but not too much.
What bits are you using?
Dormer/Presto/SKF.... and a few others are to brands. Small ones will be pretty cheap, even for top notch ones.
If you can, get stub drills, they are slightly less susceptible to snapping.
dipztik
Post by dipztik »
Sorry hitch don't know the make, packets gone, bought them from a large store in Liverpool, I'll try to pop in there tomorrow and and see have they got what you recommend.
Thanks for yer input fellas.
kellys_eye
I use drill bits from 0.4mm to 1.2mm all the time and never break a single one! Then again, I use a drill press and I'm quite used to the pressure needed so........
b
