New bathroom........Handyman not paid!!!!
This is where you can post pictures of extremely poor workmanship, whether it is done by a dodgy tradesman or by an incompetent DIY'er. Instructions on how to post pictures can be found in here.
royaloakcarpentry
Has thanked: 39 times
Been thanked: 621 times
Post by royaloakcarpentry »
Haven't a clue what exactly this 'handyman' was handy at. I only use the term handyman because this is what he called himself, I think unhandyman would be more fitting.
Everything he did in this bathroom was wrong, poor standard. The whole lot needed ripping out and doing again. He skimmed the ceiling and to be honest a 6 week course plasterer could have done better. Then painted the ceiling without mist coating first. Walls skimmed badly. he tried to fill them too and then painted over filler without rubbing down.
All framework was held together with metal plates, overboarded in hardboard, skimmed and then tiled.
Absolutely no support for the bath apart from a 2x2 batten rested on a pipe!!!!!
Shower valve, tap manifolds for bath and basin were very loose and could be shaken!! instead of back plate elbow and M/F for connection of shower, he just used a flexi hose from shower valve and used lots of silicone to stick to wall. Pipes that were plastered into the wall were void of protection. He also had joints in pipework instead of bending one length so that joints weren't in wall and plastered over.
Basin was fixed pi55ed. Chrome waste was used but instead of running the chrome into the boxing in, he joined it to white outside of the boxing.
He had no comprehension of aesthetics, levels, plumbness.
Put new floorbaords down with gripfill.
Tiling was terrible, setting out was poor. Tiled straight onto floorbaords, which lasted a week.
caused three flood and was very lucky not to have a fourth.
These are just a few of the pics.........will put pics in the showcase gallery when I have finished doing it properly.
Client hasn't paid him a penny.
Gadget
Jack Of All Trades
Has thanked: 347 times
Been thanked: 344 times
Post by Gadget »
Thats shocking, but even more shocking is that ghostly apparition in the background!
By eck! ©
OnlineOnline
royaloakcarpentry
Yeah, but it is in the mirror and so aswell as being in the background, it is in the foreground......how spooky is that.
True to form...that work done so badly was completed by a foreign national!!
Gadget
Jack Of All Trades
Post by Gadget »
Sorry, I meant to say 'ghastly apparition'... :wink:
By eck! ©
OnlineOnline
thescruff
Has thanked: 360 times
Been thanked: 3735 times
Post by thescruff »
Whats the 4" galv pipe for the tank cold water or rising mains. :scratch:
royaloakcarpentry
The galvanised is for the rainwater from the flat roof.
He scalded himself when he took rad off to fit the the towel rail....it is a one pipe system, central heating is done by the estate lol. Plumber that does a lot of work on the estate gave him a diagram of how to plumb towel rail in and he still did it wrong. Towel rail is now done correctly so that if they turn it off, the other rads in the house work.
He certainly liked a flexi fitting.
Jaeger_S2k
Pro Handyman
Has thanked: 21 times
Been thanked: 27 times
Post by Jaeger_S2k »
royaloakcarpentry wrote:True to form...that work done so badly was completed by a foreign national!!
Auch Aye The Noo'.
:oops: That's embarrassing, hard board for walls? HARD BOARD?
Don't you just love the white plastic from chrome, Lurvly!
Jaeger.
handyman
Has thanked: 6 times
Been thanked: 11 times
Post by handyman »
at least he siliconed the wall to wall joints :lol: (with a trowel)
Is the shower screen falling off the wall?
Has thanked: 1012 times
Been thanked: 918 times
Post by ultimatehandyman »
People that do work to that standard and get paid for it should be banned from ever doing it again.
It saddens me when people do work so poor and get paid for it :cb
speed
Has thanked: 35 times
Been thanked: 257 times
Post by speed »
nice work ::b
how can the home owner let it get that bad tho? id have kicked him off job long time ago
royaloakcarpentry
Handyman......No the shower screen isn't falling off the wall, that is just where his tiling isn't flat ha ha. Haven't got a clue how he did the silicone, it wasn't even as neat as some bodger who has run his finger or thumb along it. he put the bloody stuff on everything, even all behind the wall unit!!!!!!
My sentiments exactly, Speed.
Problem was that they were at work all day and moved out for some of it. Then you can add the fact that they are clueless about anything construction wise apart from what the end product should look like. By the end, it was too late.
Thing that gets me is that he came home one night and tried to criticise a bit of my tiling, which he thought was 'wonky'. Well that was until I put my 4ft level up the wall with the bubble bang in the middle and tiles touching it all the way along.........he back tracked then pmsl.
I am subbing on this one, but feel sure he is going to try to get money off to compensate himself for all the new tiles he had to buy again. Three other companys walked away, didn't even want the hassle of putting it right.
lockie
Has thanked: 32 times
Been thanked: 122 times
Post by lockie »
It amases me people use a handyman for this type of installation work.
diyguys
Has thanked: 178 times
Been thanked: 19 times
Post by diyguys »
Is that a tank above the frame?
Razor
Has thanked: 483 times
Been thanked: 1251 times
Post by Razor »
Depends what you call a handyman, I've worked with some very good allrounders and quite often they're the best choice for this sort of multi trade work.
Of course sometimes they aren't :wink:
royaloakcarpentry
Diyguys.................stack is behind the boxing and 4'' for rainwater from flat roof. Both have doglegs in them, hence why top is built out further. Although even that he cocked up with bad foresight. He had 25mm tile cuts between the part that juts out and the window reveal??!!! I have made that part of boxing 25mm deeper so it is flush with reveal.
I don't think there is anything wrong in using a handyman for that type of work, although I don't think of a handyman being beyond changing a plug, hanging curtains or mowing the lawn. If you are good enough to be pumping out quality bathrooms then I would have preferred the term of multi-trade. call me old fashioned, and certainly not meant as an insult to people who class themselves as handyman rather than mutli-trade.
In this case he wasn't handy at anything lol.
When I do this type of work, that is all I am at the end of the day....multi-trade, even though I have my City & Guilds in carpentry/joinery. Same story again when I fit kitchens.
Return to “Rogues Gallery”
