Drilling Allen key
smiffy
Has thanked: 8 times
Drilling Allen key
Post by smiffy »
Is there any way of drilling a 3mm hole through an 8mm Allen key ? I want to adapt one to use at work.
Has thanked: 740 times
Been thanked: 2355 times
Re: Drilling Allen key
you can buy security driver bits for about £5 assuming thats what you want
http://www.toolstation.com/shop/Power+T ... 650/p92461
Hitch
Has thanked: 77 times
Been thanked: 335 times
Post by Hitch »
It might be possible to drill into a cheapy set, but top quality ones probably not......
Will the security bits BA has posted up work?
Stoday
Deceased 21-10-2011 R.I.P
Been thanked: 90 times
Post by Stoday »
You can drill a hole through the centre by putting the twist drill in a vice and the allen key in a drill chuck. Rotating the work instead of the twist drill will keep it drilling through the centre of the work.
smiffy
Post by smiffy »
Unfortunately the bits that BA mentioned aren't what I had in mind - thanks anyway BA.
The hole needs to go right through the Allen key so that a roll pin can go through.
Hitch - I hadn't thought about trying a cheap Allen key. Thanks for the idea, I'll give it a go.
thescruff
Has thanked: 360 times
Been thanked: 3735 times
Post by thescruff »
Why not just bar a length of 8mm hexagon bar.
smiffy
Post by smiffy »
What I am attempting to do is make a two-in-one tool for work.
I need an 8mm Allen key and a 8mm socket for making adjustments on machinery. Rather than keep going back to the tool barrow I can keep this in my pocket.
I have managed to carefully grind one end of the Allen key to accept the 1/4 inch drive of the socket. My intention was to drill through both the socket and the Allen key together and the put a roll-pin through. The socket won't be a problem as I have done that before. I may have to try epoxy resin if I cannot drill through the Allen key
Hitch
Post by Hitch »
Ahhhh!, i see! not that way!
Know anyone with a welder?, just get is glued on, it wouldnt need to be very strong if youve ground the square on it.
Got a few special sockets kicking around that have been done like that. I dont see why an allen key wouldnt weld. Tig with a stainless filler wire i normally go for.
