- Ultimate Handyman Forum Index DIY Forum/Home improvement Electric Forum UK Lighting
- It is currently Fri Apr 11, 2025 11:55 pm
What Circuit/ Lighting Is THIS?!
Post by Willing_Learner »
From all my research this seems to indicate a circuit system?! The problem is, I have bought a light (halogen bulbs but built in transformer) the little holes to put the wires into wont take all the wires from the ceiling!
Ive attached a picture as best as I could get of the current ceiling fitting. The problem is where do all those wires go when the new light only has virtually 1 hole for live, earth etc. I have thought of using a terminal block for them all and just putting two of the original wires into the light, but I dont know and would rather check before fiddling.
Ive spoken to an electrician who basically said fitting lights is easy enough, getting a pro in will prob cost a days labour (he lives a little way away but is a friend of a friend so tried and tested) if that all makes sense PLEASE HELP!
Cheers
- Current light fitting
- light.JPG (17.27 KiB) Viewed 5149 times
Willing_Learner
- ultimatehandyman
- Site Admin
- Has thanked: 1012 times
- Been thanked: 918 times
Post by ultimatehandyman »
http://www.ultimatehandyman.co.uk/diy/e ... /index.htm
http://www.ultimatehandyman.co.uk/diy/e ... onised.htm
and here-
http://www.ultimatehandyman.co.uk/diy/e ... itting.htm
If the new light that you have bought does not have terminals in the fitting then it may be a better idea to terminate the existing wires into a choc box first, you can see how to do this on this page-
http://www.ultimatehandyman.co.uk/how_t ... lights.htm
Willing_Learner
- ultimatehandyman
- Site Admin
The blue with brown sleeve goes into the L terminal
The three brown wires are terminated into a terminal block.
The two blues go into the N terminal.
You don't really want to tape up the terminal blocks and tuck them into the ceiling as it is bad practice and so it is better if you use a chocbox like this-
There should be a terminal block attached to the new light already, or is there not one?
Also, being a big circuit, taking all the browns out, that wont affect the rest will it?! No way doubting you, but wasnt sure if I made it clear it was a big circuit, then again you probably knew that from the pic! lol
Willing_Learner
- New Light.JPG (18.21 KiB) Viewed 5137 times
Willing_Learner
- ultimatehandyman
- Site Admin
No the guide is not bad practice as the terminal is not pushed into the ceiling as you suggested. The terminal is taped up and is in the actual light fittingWilling_Learner wrote:So the guide on the link is bad practice! Naughty! A chocbox, god im certainly learning my bits for the day! So all three browns into a "chocbox" so they go in one side, but nothing out the other side, then close the box up, but where does that go? wont fit in the new light rose im sure!
Might be a good idea if you post a pic of the light fitting.
You can terminate the brown (live ) wires into a terminal block and tape it up, but I would not push it into the ceiling, I would keep it in the light fitting!
If you want to push the wires into the ceiling then a choc box is best, but then you will need to make a large hole to push it up, and the new fitting may not cover the hole that you make.
Lighting manufacturers do not consider how difficult it is to fit some fittings!
Think im basically sorted with that light then, although bit concerned about the flow of power through the actual frame!
Am going for the wires into a block and taped but NOT IN CEILING
Willing_Learner
- ultimatehandyman
- Site Admin
Is the light a low voltage light?
I have not seen one quite like this before, but they are all different.
Its got 4 halogen bulbs that you clip on, ill do some pics, and on the light it says the following:
elec transformer 110va
input: 220-240v~/50hz 0.50a
output: 11.5vac max.110w
lamp: 35-110w
the bit about 2 holes for live and 2 for neutral, the light wires going in the back only fill 2 holes. If that makes a difference!
- Light Details.JPG (13.53 KiB) Viewed 5128 times
- these are the forks that the wires go to, the screws are removed and the wire frame is screwed on
- light forks.JPG (7.6 KiB) Viewed 5128 times
- this is how the frame and lights go together
- light setup.JPG (11.06 KiB) Viewed 5128 times
Willing_Learner
- ultimatehandyman
- Site Admin
Thanks for posting the pics, they are a great help
Your light is low voltage and the voltage is transformed from mains voltage down to 12v which is much safer, hence you can touch the tracks without being electrocuted
It looks like you may be able to make the connections in the top of the light fitting, without having to push anything into the ceiling, but it's hard to tell from pictures.
So, to confirm it all...
3 BROWNS into a terminal block, one wire in each hole (so a 3 screw long block) right?
the BLUE with the BROWN sleeve into the LIVE terminal on light fitting
the 2 remaining BLUE's into the NEUTRAL on the light fitting
The earth wire into another terminal block and taped up also.
SORTED?! 8-)
Willing_Learner
- ultimatehandyman
- Site Admin
Almost right.Willing_Learner wrote:You will, the terminal blocks will fit. But may show through the frosted type plastic, but a small price to pay, and wont matter if i do a neat job!![]()
SORTED?! 8-)
The three browns all go into one terminal block, so that they are all connected together-
Liike the red wires in this picture-
You are right with everything else
Willing_Learner
- ultimatehandyman
- Site Admin
They don't need to be seperate blocks as long as the terminals are insulated from each other.Willing_Learner wrote:FINAL query then.... can I have a 2 screw long terminal block, the three browns in one hole and the earth in the next, or do they need to be seperate blocks?
So if you were to cut two terminals from a terminal strip like the one attached then that would be fine-
- terminals.jpg (10.02 KiB) Viewed 5117 times
