- It is currently Mon Apr 14, 2025 4:54 pm
[Newbie] Would anyone take on a challenge for me? (Paid)
Hi All,
I'm very new here, so I apologise if I am stepping on any toes regarding this post.
I'm in the process of converting a car from a normal petrol engine into an all electric car. Quite a big job I admit, but I can cope with most of it, apart from a small bit of fabrication I need done. I'm willing to pay for this work, but as I only need one piece machined (well, 2, but one of each) none of the local companies I've approached is willing to entertain me.
In simple terms, I need 2 pieces made, 1 out of 1" thick alu sheet, which will allow me to bolt the electric motor I have to the gearbox housing, and the other (out of steel or equivalent) is a taper lock coupler for the gearbox splined shaft to the motors keyed shaft).
I would love to be able to make them myself, however I a) don't have the skills or b) the space for the tools even though I want to learn! (Living in a flat in london..)
My question:
Does anyone here feel like they would like to help me out? I can provide cad drawings of similar products other people have made. And I am more than happy to pay or donate for the bits to be made - And I hope I'm not completely unrealistic with how much I think it'll cost - I'm thinking hundreds rather than tens!
Or
Have I asked in completely the wrong place? Can anyone give me some pointers as to where the right place to ask this kind of question / request (be it this forum, or another elsewhere).
Many thanks
Ash
My question:
Or
Many thanks
Ash
Ashev
- village idiot
- diesel demon
- Has thanked: 104 times
- Been thanked: 104 times
Re: [Newbie] Would anyone take on a challenge for me? (Paid)
Post by village idiot »
try a bearings company for the drive components
i love being married
I have a soft spot for the wife, it's a peat bog just outside Ardross
Still Yes Highland
Still Yes Highland
village idiot
- Has thanked: 77 times
- Been thanked: 335 times
Try bearingboys.co.uk for the taper lock...
The ally mounting, is it a plate that bolts on a bell housing?
Hitch
Hi Hitch,
I'll get in contact with Bearingboys.co.uk and explain what I am seeking - thanks for the link!
The adapter plate is exactly as you described, a plate to bolt onto the bell housing of the gearbox (where the clutch plate usually lives, but I've got rid of all of that) with a hole pattern to also bolt the motor on from the other (inside) side. I have plans that other people have used, but as I explained I don't have any tooling facilities.
Shouldn't 11 be pronounced "tentyone"?
Cheers
Ash
Cheers
Ash
Ashev
If it were steel, i might have been able to help, i have access to machines to cut 50mm+ thicjk steel, but not aluminium.
Have a look into getting the adaptor water jet cut, should be pretty easy if you can supply a cad drawings.
Where abouts are you based, i might be able to reccomend someone, especially if you are in the south- west.
Hitch
Hi
I'm based in london, but surprisingly there appears to be a complete lack of small metalworking shops anywhere (or possibly I simply don't know where to look!)
Kind regards
Ash
Kind regards
Ash
Ashev
Cant reccomend anyone in that area im afraid. Try a google for water jut cutting, might find one that are ahppy to review the cad drawings via email....
Hitch
- Simon Site Manager
- Has thanked: 48 times
- Been thanked: 202 times
Post by Simon Site Manager »
Ashev,
Meta Supermarkets, there's one in Park Royal NW10, they will help if they can't actually do the job.
S
S
Measure twice, cut once!
Simon Site Manager
Thanks for the suggestions - I'll give them a try next week!
Ashev
- Perry525
- Been thanked: 4 times
- Contact:
Try Jenkins 52 Hounslow Road, Twickenham, TW2 7EX
'phone 020 8894 4433
They have made things for me in the past.
Perry525
- Has thanked: 8 times
- Been thanked: 76 times
Post by Sparky James »
Using the cars normal gearbox will not be sucessful you will struggle to fix the motor to the input shaft with a drive coupling because of the gearbox splines. Also the gearbox may need a front bearing support if the car had a spiggot bearing in the crank and the gearbox has only one bearing on the input shaft. Mabe getting a flywheel machined up and using the clutch cover and drive plate would be the answer even if the clutch is not needed.
What motor are you using and whats the HP and max rpm?
Sparky James
Hi james.
Thanks for you input, and although you have some valid points, I know they are all reasonably easy to get around. I personally know people who have done conversions and they didn't suffer too many issues.
The motor is probably over specced for the weight of the car, coming in at 40kw nominal and 5600 rpm max.
Cheers
Ash
Cheers
Ash
Ashev
