Which sparky did this??
This is where you can post pictures of extremely poor workmanship, whether it is done by a dodgy tradesman or by an incompetent DIY'er. Instructions on how to post pictures can be found in here.
darrenba
Has thanked: 104 times
Been thanked: 490 times
Post by darrenba »
Just started a kitchen replacement for a client and today we had a rip out session. This was some of the horror wiring found.
The blue wires are 2.5mm - the ring comes down to a junction box (buried in the wall), spurs off to a single socket to the left then back up to the double wall socket at an odd and strange angle, another spur off to the right, and then back up the wall again at another stupid angle.
The red wires are 6mm for the oven - down the wall to the switch then down nearly to the floor and then off to the right to behind the oven unit.
The house was built in the mid 80's and this horrendous wiring was installed at build time. Were the regs that bad back then?
Horror wiring
Horror wiring
Has thanked: 1012 times
Been thanked: 918 times
Re: Which sparky did this??
Post by ultimatehandyman »
:shock:
That is a perfect example of how not to wire a house!
Sparky James
Has thanked: 8 times
Been thanked: 76 times
Post by Sparky James »
It works dont it...................................................some people are never happy :dunno: :roll:
Return to “Rogues Gallery”
