hitch
village idiot
diesel demon
Has thanked: 104 times
Been thanked: 104 times
hitch
Post by village idiot »
no, not our very helpful metalwork guru but the towing attachment that goes on the back end of a vehicle
some idiot forgot to put the pin back on the combi hitch on the pick-up after dropping off a compressor :oops:
the original pin had a reduced part on the main shank & it's replacement hasn't
i now know why the pin was reduced after trying to collect a new compressor (400cfm :thumbright: ), couldn't fit the pin because there was not enough of a gap in the throat of the hitch (between the hitch & pin) ::b
ended up using the van to collect it, lucky it was just round the corner as it was a wee bit over weight for the van at 1900kg :roll:
i love being married
I have a soft spot for the wife, it's a peat bog just outside Ardross
Still Yes Highland
Hitch
Has thanked: 77 times
Been thanked: 335 times
Re: hitch
Post by Hitch »
Im not too up on theses hitch things, isnt the different sized rings for different towing weights...i think theres also a NATO hitch, which is quite a bit larger than most standard ring hitches...?
village idiot
diesel demon
Re: hitch
it's a 3.5T hitch & when in position, the pin is held in place by both R clip & linch pin
same type as this
Still Yes Highland
