Aqua Panel
Gadget
Jack Of All Trades
Has thanked: 347 times
Been thanked: 344 times
Aqua Panel
Post by Gadget »
I have just built a shower cubicle using Aqua Panel, and the customer got the plasterer to skim it. I have always thought Aqua Panel shoud not be skimmed, so my question is: will it be okay?
By eck! ©
skiking
Been thanked: 4 times
Post by skiking »
Surely this defeats the object of aquapanel as thats cement based and can handle water/moisture rather than plasterboard that is plaster based :shock:
Gadget
Jack Of All Trades
Post by Gadget »
The AP has been skimmed, no plasterboard is involved!!
By eck! ©
skiking
Post by skiking »
That's what I'm saying....you avoid plasterboard/plaster in wet areas so adding plaster to the aquapanel completely defeats the object of using aquapanel - surely :?
Has thanked: 833 times
Been thanked: 3637 times
The problems arise if water penetrates. The weak point is the tile joints and grout lines and the join to the shower tray that is most at risk. When I replaced my shower a few years ago there were tiles stuck to ply on one wall and plasterboard the other. There was only one area where there was a wet spot which is not bad for 15 odd years of use.
I am sure tradesmen have to think about tanking so that they do not get a recall for leaks etc but care taken on tiling, grouting and jointing should be okay for a home project.
Only-Me
Been thanked: 3 times
Post by Only-Me »
No need at all to skim.........tile straight onto Ap and hardibacker.
panlid
Been thanked: 1 time
Post by panlid »
he already knows you shouldnt skim it. hes asking if, now that it is done will it be ok.
Gadget
Jack Of All Trades
Post by Gadget »
panlid wrote:he already knows you shouldnt skim it. hes asking if, now that it is done will it be ok.
Thanks for pointing that out, panlid....... I really wanted to know if the Skim will adhere to the AP, and not peel/flake off. AP is a relatively new product, and for many years tiles were stuck to walls that had been plastered using traditional methods,ie..'browning' then a coat of finish (skim). In fact, my shower area (bath) is tiled exactly how I describe, and after 21 years it is still ok!
By eck! ©
tim'll fix it
Post by tim'll fix it »
tradional plaster is fine
AP is used to replace ply and plasterboard which are poor substrates
panlid
Post by panlid »
gadget, certain people round here dont like you mentioning things like that :lol:
skiking
Post by skiking »
How is the plaster going to react when it gets wet i.e when the grout fails and water soaks thru'?
tim'll fix it
skiking wrote:How is the plaster going to react when it gets wet i.e when the grout fails and water soaks thru'?
I expect it will explode
Gadget
Jack Of All Trades
Post by Gadget »
If it's tiled correctly (water proof adhesive) ,and grouted correctly, that won't happen. My question was:..will the skim stick to the AP!!
By eck! ©
panlid
Post by panlid »
yes. the aqua panel still takes moisture, its just that it doesnt rot.
Only-Me
Post by Only-Me »
Should be ok :thumbright:
Return to “Tiling Forum”
