How to stop rust without removing it
redyukon
Post by redyukon »
Hi, I'm an artist and I am planning to work with metal materials for a series.
For most of them I will need to partially oxidize the metal, then stop the rusting and fix it.
I'm guessing I would have to "kill" the active oxygen agent and then layer the whole sheet with a protecting agent but I don't know how.
Thanks for reading, and hopefully for answering.
Has thanked: 740 times
Been thanked: 2355 times
Re: How to stop rust without removing it
hammerite smooth or hammered finnish avalable in differen colours
http://www.hammerite.co.uk/index.html
Bob225
Has thanked: 106 times
Been thanked: 882 times
Post by Bob225 »
there a few ways to start the rust, heres just one site off a google search..................
http://gomakesomething.com/ht/age/rust-guide/
rust is like fire kill the oxygen and it kills the flames - kill the oxygen it kills the rust
an acrylic or matt lacquer will do the job
redyukon
Post by redyukon »
thank you gentlemen.
rotciv
Has thanked: 11 times
Been thanked: 18 times
Post by rotciv »
Would love to see your completed works.
Dreams contain the seed of success..... (if you manage to wake up.)
Has thanked: 833 times
Been thanked: 3636 times
You could buy a Lancia and save a lot of trouble :lol:
OnlineOnline
thescruff
Has thanked: 360 times
Been thanked: 3735 times
Post by thescruff »
Years ago I bought some stuff called stop rust, I think it was made by Comma.
Anyway it turns the rust to Magnetite.
Beachcomber
Has thanked: 28 times
Been thanked: 71 times
Post by Beachcomber »
Hammerite will work if you can cover both sides of the metal - if there is an unaccessable part of the structure (inside of a tube etc) rust will burst back through the hammerite finish as it's still being fed from the other side.
I've just got some of this to try:
http://www.toolstation.com/shop/Paintin ... 152/p43408
Not used it yet but hoping it solves the problem before the cab falls off my van! :lol:
If at first you don't succeed - remove all evidence that you tried.
Mooncat
Has thanked: 81 times
Been thanked: 72 times
Post by Mooncat »
Beachcomber wrote:Hammerite will work if you can cover both sides of the metal - if there is an unaccessable part of the structure (inside of a tube etc) rust will burst back through the hammerite finish as it's still being fed from the other side.
I'll back this up. We had an old caravan with a rusted steel chassis. Spent ages wirebrushing, scraping and cleaning. Two coats of Hammerite, but two years later, the rust was coming back.
