Removing scratch marks from a fridge door!
jman316
Has thanked: 14 times
Post by jman316 »
Im desperate for your help! :(
Just bought a new fridge. The missus in her infinite wisdom, whilst cleaning it used to the wrong side of the sponge and has scratched a whole area on the fridge door!
Its a brushed stainless steel service. Can anything be done to fix this?
Please help!
Simon Site Manager
Has thanked: 48 times
Been thanked: 202 times
Re: Removing scratch marks from a fridge door!
Post by Simon Site Manager »
Hi Jman,
You will need to polish out the scratches, you will need a cutting compound suitable for stainless, then rub in the direction of the brushed effect. Could take a long time!
S
Measure twice, cut once!
jman316
Post by jman316 »
Some sites suggest Scotchbrite....dont know if that will work.
what you suggest sounds beyond my skill range :(
Simon Site Manager
Scotchbrite is scourer which probably caused the problem in the first place. There are people such as Door Doctors who may be able to help. The job is do-able, just need the technique.
S
jman316
Post by jman316 »
Simon Site Manager wrote:Scotchbrite is scourer which probably caused the problem in the first place. There are people such as Door Doctors who may be able to help. The job is do-able, just need the technique.
S
This sounds something beyond my skill set.! :(
Hitch
Has thanked: 77 times
Been thanked: 335 times
Post by Hitch »
How bad is it, just few light scratches?
Brushed finish stainless is quite easy to repair, a medium or coarse Gary-block (diamond inmpregnated rubber block) a few rubs in the grain direction, you need to keep it in long straight runs, easing of pressure start and finish of each
Different story if its lacquered though.
jman316
Post by jman316 »
Hitch wrote:How bad is it, just few light scratches?
i can post pictures of the said scratches for you guys to review and then make a better judgement as to what i should do! Will that be ok?
thescruff
Has thanked: 360 times
Been thanked: 3735 times
Post by thescruff »
Go for it, pics are always good.
Has thanked: 740 times
Been thanked: 2355 times
might be worth replicating the problem on an area out off site and experiment there first just in case :?
jman316
Post by jman316 »
I add a picture for your perusal....
Hopefully this will make things a little clearer!
your freezer should be on -18 to 21 :lol:
Hitch
Post by Hitch »
Difficult to tell, but its smack in the middle of the panels, cant really tell what kind of polish it is, looks like a fairly fine grained?
I think even the gary-block method wouldn't create an invisible repair, but worth a go. See how it goes on a trial patch somewhere if possible.
A good coat of baby oil might take the eye off it afterwards.
jman316
Post by jman316 »
big-all wrote:your freezer should be on -18 to 21 :lol:
lol really? i thought -14 would be cool enough! ill adjust it!thank you :)
jman316
Post by jman316 »
Hitch wrote:Difficult to tell, but its smack in the middle of the panels, cant really tell what kind of polish it is, looks like a fairly fine grained?
ill try and take a few better looking pics!
where would i get the gary-block thingymajig?
thescruff
Post by thescruff »
Looks to me like it has a lacquer or something on it, and I don't think it's just polished.
