Sticking aluminium to aluminium
Welderpaul
Has thanked: 2 times
Been thanked: 1 time
Post by Welderpaul »
Need to stick some 2omm wide x 3mm thick ally onto some larger section ally. It must be a permanent bond and will get some stick during its life.
Can anyone recommend a good adhesive i can use?
Thanks! :-)
Has thanked: 740 times
Been thanked: 2355 times
Re: Sticking aluminium to aluminium
contact adhesive would be ideal something like evostic
http://www.screwfix.com/prods/42076/Sea ... ive-2-5Ltr
deltaireng
Post by deltaireng »
You might want to try Plastic Padding Chemical Metal,
http://tinyurl.com/33eegda
(I have shortened the link and activated it. Mod5)
I have used it for vehicle body repair and it works well.
Hitch
Has thanked: 77 times
Been thanked: 335 times
Post by Hitch »
3m scotchweld, and the approporiate primer....
A quick scout says 3901 for primer, and 490....for the actual adhesive.
Its a 2part adhesive, epoxy.
The 490 rings a bell. Good stuff as long as its used properly, as with most chemicals.
Welderpaul
Thanks for your help fellas :thumbright:
royaloakcarpentry
Has thanked: 39 times
Been thanked: 621 times
Post by royaloakcarpentry »
Weld it. That is pretty solid.
Stoday
Deceased 21-10-2011 R.I.P
Has thanked: 8 times
Been thanked: 90 times
Post by Stoday »
Braize it. Bit like silver soldering only with an aluminium alloy "braizing" rod. Requires less skill because the filler melts well below the melting point of aluminium.
http://www.ultimatehandyman.co.uk/easyw ... minium.htm
