range rover p38
derekholden
Has thanked: 4 times
range rover p38
Post by derekholden »
Does anyone have any problems with the battery being drained on the p38 range rover. If I charge it up it lasts about a 2-3 weeks. I've had the battery and altenator tested and apparently both are fine. thanks
Razor
Has thanked: 483 times
Been thanked: 1251 times
Re: range rover p38
Post by Razor »
If you have an intermittant misfire as well they are notorious for the earth lead shorting out on the exhaust pipe.
These users thanked the author Razor for the post:
derekholden
derekholden
Re: range rover p38
cheers I'll check that out.
Has thanked: 1012 times
Been thanked: 918 times
Re: range rover p38
Post by ultimatehandyman »
You also might have something draining the battery, such as a glove box light that is not going out etc.
These types of fault can be a real pain in the backside to find sometimes.
diggerdog36
Has thanked: 25 times
Been thanked: 5 times
Re: range rover p38
Post by diggerdog36 »
I had the same on a Discovery 2 which is similar, but mine was draining overnight!! Here is what I followed... http://www.wikihow.com/Find-a-Parasitic-Battery-Drain mine was an Active Hill Descent solenoid staying permanently energised.
Robotstar5
Has thanked: 8 times
Been thanked: 8 times
Re: range rover p38
Post by Robotstar5 »
P38's can be prone to external RF signals (radio transmitters etc.) "waking up" the car electronics and draining the battery. Can't remember if there is a fix, might be worth having a look at one of the Land Rover forums?
sean_ork
Been thanked: 9 times
Re: range rover p38
Post by sean_ork »
Robotstar5 wrote:P38's can be prone to external RF signals (radio transmitters etc.) "waking up" the car electronics and draining the battery. Can't remember if there is a fix, might be worth having a look at one of the Land Rover forums?
the fix usually involves the removal of the antenna
www.landyzone.co.uk will have the answer
