What's lurking behind the wallpaper
This is where you can post pictures of extremely poor workmanship, whether it is done by a dodgy tradesman or by an incompetent DIY'er. Instructions on how to post pictures can be found in here.
jmcp
Has thanked: 25 times
Been thanked: 14 times
Post by jmcp »
been working on a house doing some basic diy like stripping wallpaper, patching walls, painting them, building retaining walls in the garden etc... nothing major and in no real order, been doing it all as and when I had time and the energy but got to the stage were I was about to tackle the kitchen, thought it would be a case of stripping off the old vinyl wallpaper and tile it but what I found with the electrics was pretty scarey, to me anyway, pictures below, oops, please view these pictures form the bottom of the note as they are in the wrong sequence. This last picture is of the consumer unit, can you tell by this picture that if it looks like only half the house has been rewired ? I am currently arranging for a qualified electrician to come out and do a full report on the electrics but thought I would let you see this and find out what you think.
Cheers, John
Consumer unit
Consumer unit
Under the worktop
Under the worktop
Under the worktop
Under the worktop
Under the worktop
Under the worktop
Under the worktop
Under the worktop
View under the worktop once I pulled the tumble dryer out
behind the "click" cardboard packing
Chipped away the plaster from the old socket
A screw was used to fix a bit of trimming round the worktop that was very close to going right through the cable
cable not chased into the wall properly
This is the bare wall from behind the paper.
Colour Republic
Has thanked: 263 times
Been thanked: 544 times
Re: What's lurking behind the wallpaper
Post by Colour Republic »
This one I like very much because i've never seen a compression joint leak ::b
Has thanked: 1012 times
Been thanked: 918 times
Post by ultimatehandyman »
OMG, that was a disaster just waiting to happen!
jmcp
Post by jmcp »
Any comment about the consumer unit, does it look like there is old styling cabling running out of it as well as modern cabling ? I was thinking it looked like there has been a partial rewiring of the house rather than a full rewiring ?
Cheers, John
jmcp
Post by jmcp »
Colour Republic, can you comment more about the plumbing issue you see, I guess it is to do with the plastic pipes etc... but not being a plumbing expert or anything like it I don't see any issues there ?
Cheers, John
jmcp wrote:Any comment about the consumer unit, does it look like there is old styling cabling running out of it as well as modern cabling ? I was thinking it looked like there has been a partial rewiring of the house rather than a full rewiring ?
Cheers, John
It's a strange setup to be honest and I am not sure if someone has been messing about with it, possibly to steal electricity at some point.
I have seen plenty of consumer units, but I have never seen on where the main incoming cable goes to the main fuse before the meter. All the ones I have seen go to the meter first and then the main fuse :scratch:
Also that main incoming cable looks like a right bodge job, is this in a rural location?
The cables exiting the consumer unit look ok from here, the cables at the back of the unit or they white or have they been painted white?
thescruff
Has thanked: 360 times
Been thanked: 3735 times
Post by thescruff »
Mine go into the main fuse first chez, although mine has live and neutral going into a 100amp fuse box or whatever it's called.
dave.m
Deceased 07-06-2012 R.I.P
Has thanked: 13 times
Been thanked: 318 times
Post by dave.m »
Ours went Main Fuse -> Meter -> CU. when we had the last house, but, as Scruff says, both live and neutral went into the fuse casing.
dave
But you cannot tell him much.
northwales4u
Has thanked: 76 times
Been thanked: 151 times
Contact:
Post by northwales4u »
Just checked mine and here it is Meter > Fuse > CU but over the road it is Fuse > Meter > CU
Mike
jmcp
Post by jmcp »
Cheers, John
the house is an ex council house in a housing estate. I was thinking that someone at some point has paid to get the house required and that someone has just done a partial job ie upgraded the fusebox and fed new cables down stairs. The walls in the house are all concrete and I suspect that is why they did such a shoddy job with the chasing in of the cables, probably was too much hassle for them.
Cheers, John
thescruff
Post by thescruff »
If the walls are concrete it is likely to be a prefab, and you don't go chasing into that,
royaloakcarpentry
Has thanked: 39 times
Been thanked: 621 times
Post by royaloakcarpentry »
Ha ha someone used to enjoy going to B&Q on a Friday in readiness for a bank holiday weekend!!!! I bet their wife used to say how lovely it all looked and gob off to her friends about how handy her hubby was...........mind you, could also be a womans handy work lol
Crooksey
Been thanked: 72 times
Post by Crooksey »
Haha RO far to true!
I have seen some really dodgy work done in council houses. Normally when the walls are concrete you just use trunking to conceal the wires!
I once had a friend who lived in one and he shower was not working, so I took a quick look- someone had wired it into the lighting circuit :? I told her to get the council out to sort it :wink:
Of all the houses I have been in I have never seen the main incoming cable go to the fuse first!
My mate had an incoming mains cable in his house that was split before the meter and then went through a hole in the wall into next door, where that then went to her meter. I guess there are all kinds of weird arrangements up and down the country :roll:
jmcp
Post by jmcp »
I have an Electrician coming to see it on Wednesday evening and he has experience of the houses in this road so hopefully things will be a lot clearer after that visit. Will let you know how it goes.
Cheers, John
Return to “Rogues Gallery”
