Vito Injector
jay81
Been thanked: 5 times
Vito Injector
Post by jay81 »
Hello Everyone
Has anyone had any experience in trying to change a Vito Injector.
I have one that has a bad leak off problem.
Cheers
Jason
THERE IS ONLY ONE HOTSPUR!!!!!!!!
Blakey
Has thanked: 247 times
Been thanked: 48 times
Re: Vito Injector
Post by Blakey »
Soak the injector for a couple of days in penetrating oil, Start the engine and let it run until it gets up to 80 deg. The carbon gunk softens and the injector should come out - just twisting side-to-side with a spanner. or you could apply some heat around the injector with a heat gun?
Coca cola is known to work instead of penetrating oil as it is a metal injector in aluminium head, but they can be a real pain (good luck)
