vw caddy sdi 1.9
fipple
Has thanked: 1 time
vw caddy sdi 1.9
Post by fipple »
Hi,...Brought this caddy oct 2010...im getting water coming onto the passenger footwell everytime it rains.It seems to come in down through the heater blower(ive got a pollen filter on the opening under the hood,so not sure hows its getting in)..i notice water coming out through the vent which has a small electrically kind of heater in it...keeps blowing my connector..Anyways before i get lost in the description..does anyone know how i go about stopping the rain water entering the footwell...ive heard its a problem with caDDys ::b :cussing:
keithjeb
Has thanked: 3 times
Been thanked: 16 times
Re: vw caddy sdi 1.9
Post by keithjeb »
May be completely unrelated, but I had the smae issue with an old starlet. One of the bungs (presumably for wiring/something that wasn't fitted) had popped out, just a little rubber circle. It was fairly obvious with the carpet peeled back, might be worth a look.
ayjay
Has thanked: 458 times
Been thanked: 1708 times
Post by ayjay »
Under the pollen filter box is a gasket which is supposed to be replaced on a full service but it never is, this has almost certainly perished, I replaced mine (on a Passat) with large helpings of silicone.
The other usual reason for water to get in (Passat again) is because of a blocked drain under the battery box, the water fills it up and comes through holes in the bulkhead.
fipple
Has thanked: 1 time
Post by fipple »
thx keith ,will check tht out :thumbright: Ayjay!...i know where your coming from,i checked the area where the filter goes but the weathers been bad (no garage) so will check it again maybe tomorrow...its quite a hard area to get to as i have a flimsy drip cover thats a nightmare to remove...but i think i will clean it as best as i can,then put lots of sealant(silicon) and hopefully tht will cover it :salute: ...but its defo coming into the car in tht area....cheers for your help the both of u :thumbright:
Raf
Has thanked: 1 time
Been thanked: 4 times
Post by Raf »
on most cars the scuttle panels get clogged with leaves so water drains into footwell.
