Kitchen cornice
Posted: Wed Aug 29, 2007 3:11 pm
by The Weegie
Hi all,
I recently installed kitchen cupboards, I mitred the cornice for the bottom of the unit, and it was fine, however when I went to screw it on I noticed that when I brought the two bits together the cornicing at the back of the unit wasn't in line with the front of the unit. (I hope this makes sense?). I again made another cut but the same problem occured. Any ideas as to why this happened.
I used a mitre compound saw at exactly 45 Degrees
I have mitred plenty of other materials with no problems. Can't understand why this happened.
Any advice would be appreciated
Posted: Wed Aug 29, 2007 4:53 pm
by jason123
If the cornice has 3 flats on the back, and you are mitreing with it on its back, then the mitre will be correct only if the flats are secured to the cupboards. The mitre has to be cut with the flat to be screwed to the cupboard flat in the saw, hope that makes sense.
Posted: Sun Sep 02, 2007 10:08 pm
by The Weegie
Thanks for the advice Jason123.
