Laminate floor layer in Bexhill
- Has thanked: 47 times
So-called professional floor layer did this: (1) Cut both underlay and laminate all jaggedy around fireplace hearth (2) slapped some filler in any old how. and (3) used my newly-restored Victorian handrail to saw scotia. When I asked him nicely to put things right he stormed off, slamming my door so hard it nearly came off its hinges. Helen, Hastings.
(Pics were previously posted on the flooring forum, duplicating here in case anyone missed them!)
- thescruff
- Has thanked: 360 times
- Been thanked: 3735 times
- 54aardvark
- Has thanked: 16 times
- Been thanked: 56 times
Re: Laminate floor layer in Bexhill
Blimey, thats horrible!
Cut lines all over the place, he obviously marked out the boards individually rather than taking a line together before cutting and even then he couldn't keep his jigsaw straight
That filler looks like 2 pack (correct me if I'm wrong) which will give a pinch area as its solid.
As for your bannister - that is unforgiveable, one cut is bad enough but to compound the problem.........
Did you pay him before he slammed out? He doesn't deserve paid with a job like and you're still left with a mess - would love to help sort it for you but its a wee bit far to Bexhill!
- These users thanked the author 54aardvark for the post:
- novice-in-sx
There are no problems - only solutions
Cheers Mont, there is a whole thread about this, so I won't repeat it!
- wine~o
- Has thanked: 1415 times
- Been thanked: 4029 times
Straight cuts with a straight saw..surely54aardvark wrote: and even then he couldn't keep his jigsaw straight
- Has thanked: 35 times
- Been thanked: 257 times
i use a jigsaw for all cuts, reason being that all cuts are covered so dont matter if there not perfect straight and a jigsaw blade is <£1 so cheap enough as opposed to a handsaw which is +£7 of chopsaw blade that is £40+wine~o wrote:Straight cuts with a straight saw..surely54aardvark wrote: and even then he couldn't keep his jigsaw straightjigsaw is for going round difficult bits...
back to the op, if that filler is solid its useless, may as well have just cut it tight to the cupbard,
- Has thanked: 39 times
- Been thanked: 621 times
Jigsaw all the way.............never come across a fitter who uses a hand saw.
- Gadget
- Jack Of All Trades
- Has thanked: 344 times
- Been thanked: 343 times
Unlikely that it's '2 pack'- can you see someone who seems to have no idea how a job should look on completion spend time mixing '2 pack' ?? ...he would just shove in some (very badly in this case) coloured filler
By eck! ©
- BONEStheBUILDER
- Been thanked: 11 times
it looks like the coloured filler in a tube , and then tried to smooth it with his big toe
- nick200
- Has thanked: 409 times
- Been thanked: 222 times
It does not look good. I saw your other thread so I know that it was a nightmare. Hope you get it sorted.
Nick
- Gadget
BONEStheBUILDER wrote:it looks like the coloured filler in a tube , and then tried to smooth it with his big toe
That's rediculous- how could he smooth it with his big toe when it's pretty obvious he was wearing 'cowboy' boots at the time?....
By eck! ©
- BONEStheBUILDER
