Drilling through Tile or Grout?
Hoovie
Borders Bodger
Been thanked: 4 times
Post by Hoovie »
Fitting a Glass Shower Screen and a 1100mm Towel Radiator, so both are both fairly significant in weight
The Shower Screen support will be screwed through a tiled wall, through Aquapanel and then into a Stud Wall Batten
The Tower Radiator supports will be screwed through a tiled wall, through a plaster and lath wall and into the vertical batten.
Is it better to drill and screw through the Tile itself or between the Tiles into the Grouting to secure these items?
Cheers,
Hoovie
:salute:
Has thanked: 1012 times
Been thanked: 918 times
Post by ultimatehandyman »
I don't think it will make a difference to be honest. Some people drill the grout as it is easier to drill through. As long as the holes are in the correct place then I do not see as it matters :wink:
Also make sure the holes in the tiles/grout are big enough :wink:
Hoovie
Borders Bodger
Post by Hoovie »
I've always gone throught the grout before based on fear of cracking the tile through cackhandedness :oops: but thought it may be time to face my fear :shock:
:lol:
It's still possible to crack a tile if you drill the grout if you use the incorrect drill bit and it bites.
What type of drill bit are you using?
Hoovie
Borders Bodger
Post by Hoovie »
The tiles are only basic clay ceramic tiles, but as a precaution I bought a "tile drill bit" from BnQ - it is a 'tungsten carbide tipped drill bit'
Went for 8mm to give a bit of an oversize hole to make sure tile wouldn't be stressed and then which I thought I could fill with white silicone before screwing through to seal up and waterproof.
It's probably like this then-
They should easily drill through ceramic :wink:
I don't think you will have any problems with it.
Hoovie
Borders Bodger
Post by Hoovie »
yup - just like them :thumbright: I think I read a posting that said a gentle tap with a centre punch is a good idea to get started.
I'd use some masking tape to be honest, that will make it easier to start the hole.
Only-Me
Been thanked: 3 times
Post by Only-Me »
And make sur the plug is flush with the wall.......................NOT THE TILE :thumbright:
In other words........drill ya hole through ya tile and into wall........then drill a slightly bigger hole in just the tile, so the plug can be pushed in flush with the wall.
:thumbright: :thumbright:
jason123
Post by jason123 »
A small masonry bit set on normal drilling will go through the glaze of a tile, then use your tile bit.
Stella Stella Stella oy oy oy
Hoovie
Borders Bodger
Post by Hoovie »
Only-Me wrote:And make sur the plug is flush with the wall.......................NOT THE TILE :thumbright:
Reckon I should put a wall plug in the hole then? even thought the screw will be held ultimately by the wood battening?
Nope, I'd just screw into the batten :wink:
panlid
Been thanked: 1 time
Post by panlid »
hoov if its going into the stud no need for a plug. just make sure you dont try to overtighten it ::b
Only-Me
Post by Only-Me »
Did'nt read the bit about battens :oops: :oops:
bathstyle
Post by bathstyle »
A little tip when drilling into ceramic tiles, use the sharp point of a screw to break the glaze before drilling the tile, just tap it with your hammer.
Return to “Tiling Forum”
