Van vault
Hitch
Has thanked: 77 times
Been thanked: 335 times
Van vault
Post by Hitch »
I beleive one or two of you have Van vaults, or similar things?
Just sized one up, ideally id want one about 1100/1200 long and about 600x600, but pretty expensive, one about the size i want is about £300 :shock:
Any links for suppliers of similar thing, before i start building one :lol:
Gadget
Jack Of All Trades
Has thanked: 347 times
Been thanked: 343 times
Post by Gadget »
By eck! ©
Wood Magnet
Been thanked: 3 times
Post by Wood Magnet »
Make your own out of wood ! Save money. :thumbright:
People forget how fast you did a job - but they remember how well you did it.
I no longer skinny dip, i chunky dunk these day's.
Rich-Ando
Pro Tradesman
Has thanked: 135 times
Been thanked: 304 times
Post by Rich-Ando »
Wood Magnet wrote:Make your own out of wood ! Save money. :thumbright:
in my old van i made one out of 1" Ply (which is pretty hard stuff to cut).
i put a massive lock on the box lid and i also used a 13mm threaded bar. drilled a whole through the end of the bar and welded an angle bracket on the other end. this bar slid through from the back of the van to behind the passengers seat where i put a pin through.
now if anybody wanted to nick my tools they had to break into the back, somehow get around the large lock i had on it and then if they managed that, then had to break into the front to remove the pin holding the other bar.
all of the above worked a treat and prevent anybody from nicking my tools. the problem being though, i got increasingly annoyed at having to undo both of them every single morning and subsequently ended up not bothering to lock it half the time.
Hitch
Post by Hitch »
I thinkl i will make one up, cant justify £250 when it would only cost me about £50 and a couple of hours of my spare time. :thumbright:
Get it the size i want then aswell.
bathstyle
Post by bathstyle »
I have a vault in my van, I put all the valuable tools in there and have it locked at all times, even during the day.
The way I see it is that a Van can be broken into so quickly so if you have tools loose in the back then treat the van as being unlocked.
Stoday
Deceased 21-10-2011 R.I.P
Has thanked: 8 times
Been thanked: 90 times
Post by Stoday »
Err...
How do you stop 'em nicking your van Bathstain?
handyman
Has thanked: 6 times
Been thanked: 11 times
Post by handyman »
Stoday wrote:Err...
most of the wee s**ts that steal out vans, steal out vans, not steal the van.
I would guess there will be a statistic you can google on the subject
Jaeger_S2k
Pro Handyman
Has thanked: 21 times
Been thanked: 27 times
Post by Jaeger_S2k »
Hitch wrote:I thinkl i will make one up, cant justify £250 when it would only cost me about £50 and a couple of hours of my spare time. :thumbright:
Hitch if this is near Ebay Van Tool Box, if not have a quick search, these are mostly Collection Only and can be had from around £50 to £75.
I just picked up a Van Guard Solid Bulk Head for the Expert (brand new never fitted, well it is now!) :thumbright:
PS If you're making one, make two (I'll go measure up :lol: )
Jaeger.
Hitch
Post by Hitch »
I saw that one last night, a bit small. Looks very home made, with its pop riveted construction, a few cracks with a hammer and chisel and the rivets will be gone and your in :scratch:
terrys_plumbing_bits
Post by terrys_plumbing_bits »
ill price 1 up for you if u want, my works sells them so ill let u know
Hitch
Post by Hitch »
Dont worry about it, cheers anyway Terry :thumbright:
Telmay
Been thanked: 2 times
Post by Telmay »
More work for Hitch then, something else you can make and flog mate :lol:
chippymike
Has thanked: 16 times
Been thanked: 9 times
Post by chippymike »
Hitch i belive you have a partner van were was you going to place it behind the seats? just out of interest :thumbright:
Hitch
Post by Hitch »
Its a berlingo, so yeah, identical.
It will go up to the lower section of the bulkhead, and upto the front of the wheel arch, full width.
That will give me enough room for 2 routers, circ saw, cordless drills, sds drill... sanders, plus extra space.
That keeps the majority of the load space free- long stuff will sit ontop of it.
I must hurry up and build it :roll:
