- Ultimate Handyman Forum Index DIY Forum/Home improvement Electric Forum UK Lighting
- It is currently Sat Apr 05, 2025 4:34 am
Two switches
Two switches
I've just replaced a standard pendant with a Next light fitting (in the utility room). Unfortunately I didn't take note of how the original fitting was wired. There are two switches but there is only one cable coming into the light -it's three core and earth.
The switch by the kitchen door used to switch on the kitchen lights and the utility light. As did the switch in the utility room.
Now I can wire it so the utility switch does the utility light. And the kitchen switch does the kitchen light. But neither switch does both!
If I put the red wire and the wire with a red jacket on together, the utility light is permanently on.
Any help would be gratefully received.
ajb019
- ultimatehandyman
- Site Admin
- Has thanked: 1012 times
- Been thanked: 918 times
Post by ultimatehandyman »
I have never seen 3 core and earth cable at the ceiling rose before
Have you tried connecting the red wire to one of the wires on the light fitting and the wire that is sleeved red to the other wire on the light fitting?
MAKE SURE YOU DONT CONNECT ANY OF THE CIRCUIT WIRES TO THE EARTHING WIRE (if there is one)
If that does not work Markysparky will be familiar with that kind of setup and may be on later to answer!
ajb019
- ultimatehandyman
- Site Admin
Not sure about that wire, it may go with one of the other wires or it may not. Best wait till markysparky answers, hopefully he will be on later.
As I said before I have never seen 3 core cable before at the ceiling rose and so it is best if I leave the answer to someone that will know for definate, rather than me guessing!
Glad you like the site
- Electrician
- Contact:
Re: Two switches
Post by markysparky »
This appears to be a feed and switch wire joined together. The one with red sleeving on. Put this into the live of the light fitting and see what happens.ajb019 wrote:I've just replaced a standard pendant with a Next light fitting (in the utility room). Unfortunately I didn't take note of how the original fitting was wired. There are two switches but there is only one cable coming into the light -it's three core and earth.
As for the rest of it. If you look in the switches and the lights concerned and tell me what there is.
I might be able to help you out a lot more
markysparky
Thanks, I've tried that and it works from the utility switch only.
In the light fitting there is one three core and earth cable coming in - one green/yellow, one blue (with black jacket), one yellow (with red jacket) and one red.
I need to have a look at the switches and let you know.
The utility switch is a single switch.
The kitchen switch has three switches - one operates the lights under the cupboards, one operates one half of the kitchen lights and the other SHOULD operate the other half of the kitchen plus the utility lights.
Thanks for helping
Thanks for helping
ajb019
- Electrician
- Contact:
Ok your utilty room switch is 2 way. You've got a 3 core at the light fitting but with the sleeved wire only connected into the light the switch at the utility room works but the one by the kitchen door doesn't?ajb019 wrote:Thanks, I've tried that and it works from the utility switch only.
Thanks for helping
Doesn't make sense!
Either there is another cable missing at the light you replaced or you've replaced another light fitting or switch and not terminated correctly!
Have you?
markysparky
At the utility switch there are three cables:
red, black, earth *2
red, blue, yellow with red jacket, earth
black, black and blue are connected
earths are together
all reds in one switch terminal
yellow with red jacket in the other switch terminal
At the kitchen switch there are 5 cables, all red, black, earth
all earths are together
3 reds go to top three switch terminals
1 red goes to bottom right switch terminal
1 red goes to bottom left switch terminal
2 small red wires connect the three bottom switch terminals
all blacks together
Markysparks, I bet I've missed out a wire at the light fitting like you suggested!
earths are together
all blacks together
ajb019
ajb019
- ultimatehandyman
- Site Admin
I keep trying to imagine the configuration but cannot, it sounds like the neutrals could be in the switch backboxes rather than at the ceiling rose.
Perhaps if you could post a couple of pictures someone may be able to answer?
It is very difficult to try and guess which wire goes where by reading a description.
- Electrician
- Contact:
Am I right that both the utility and kitchen swithces are both 2 gang 2 way?
And you want them changed till 1 gang 1 way! is that correct?
markysparky
ajb019
amarg
