Best tools for fitting laminate
jason123
Post by jason123 »
I have done it before with a jigsaw :shock: , Im just thinking that laying the floor at 45 degrees, thats an awful lot of mitre cuts to do, what do you recommend, cheers, Jas
Stella Stella Stella oy oy oy
Has thanked: 1012 times
Been thanked: 918 times
Post by ultimatehandyman »
Chop saw, you can just adjust it to the correct angle and lop it off each time :thumbright:
I'd lend you mine, but a friend has it at the minute ::b
jason123
Post by jason123 »
I saw a really flimsy one in B&Q yesterday, it had really flimsy plastic feet, just asking to break off, how much do they start at with a metal base???
jason123
Post by jason123 »
b*llocks, the laminate boards are 156mm wide thats 220mm when mitred :cb
Not sure how much a decent one starts at.
A jigsaw will still cut them easily, or a circular saw.
You could do with making a template then it would be a doddle.
owen
Been thanked: 1 time
Post by owen »
i would not use a chop saw, the laminate will blunt the blade very quickly.
i always use a jigsaw as the blades are cheap to replace, i get through a couple per room usually.
Hitch
Has thanked: 77 times
Been thanked: 335 times
Post by Hitch »
Jiggasawus, cut upside down saves the edges ;)
tim'll fix it
Post by tim'll fix it »
jigsaw it :thumbright: owens right you will have f*ck the blade by half way across the room
jason123
Post by jason123 »
I really wanted to buy an expensive bit of kit :cb jigsaw it is then, again :cb
Id convinced the mrs I needed a sliding compound mitre saw, she even said, if you need it get it :cb
More downcut blades for Jason :cb
Gadget
Jack Of All Trades
Has thanked: 347 times
Been thanked: 344 times
Post by Gadget »
Jase, tell Ms J this is the only tool that will cut laminate flooring accurately, so you really need to buy it!. http://www.screwfix.com/prods/63169/Pow ... e-Saw-240V
By eck! ©
Hoovie
Borders Bodger
Been thanked: 4 times
Post by Hoovie »
On the advice of Carhartt Kid, I bought one of these -
BAHCO Superior Hard Point Laminator Handsaw
and will be using Metal jigsaw blades for the tricky and curvy cuts (cheers Chez :thumbright: )
Has thanked: 740 times
Been thanked: 2355 times
i use jigsaw 101b or d blade[several]
combination square great marking line accross or along the full length or at 45%
can also be handy for measuring the distance of pipes or other uneven surfaces by sliding the head along the ruler untill it touches the pipes ect
fretsaw /jigsaw fine blade for fine work [several spare blades]
handsaw /sharp chisel for undercutting frames
fixing kit/hammer
loads of pencils
and last of all if i use quad if i can i use wooden quad painted the colour of the skirting and costs around 50p a meter :thumbright:
OnlineOnline
jason123
Post by jason123 »
Cheers fellas,
Gadget, the 45 degree cut is 218mm I know the board would probably snap the remaining two mm, but at nearly £600 I think its a bit expensive for a tool that nearly does the job.
Hoovie, I dont mind a bit of sawing but too much and I get careless and sloppy as I get tired, usually about halfway through the first cut.
Big Al, Im going to grind the teeth off a knackered old saw, and use it for marking out. I always like length of them when sorting out 90 or 45 cuts. I have marked woodwork with the teeth before hence grinding them off, oh and every so often the lad wants to help, he can have a race with me sawing timber :thumbright:
Hitch
Post by Hitch »
Get the chopsaw, youll win everytime :lol:
I got some of theese bosch blades the other day, cuts nice tight curves. :thumbright:
http://www.screwfix.com/prods/36303/Bla ... net-T101AO
jason123
Post by jason123 »
Which chopsaw Hitch, it has to do a 220mm cut length when mitred
Return to “Tool Talk”
