Right angle drills
Cannyfixit
Has thanked: 102 times
Been thanked: 183 times
Right angle drills
Post by Cannyfixit »
Im in negotiatiation with my boss as to why he needs to buy me a right angle drill,my job is fitting Beer lines behind the bar and i have to drill combinations of 1" 2" 3" holes using hole cutters,as some of you may appreciate getting access to the back of the bar is a right pain in the butt hence the need for a angle drill.
So if i was to drill half a dozen 3" holes what angle drill would be the best buy looking for something that wouldnt burn out after a few uses as this will be a one off purchace the boss is a tight arse :cb
Oh and it needs to be 110 volt :thumbright:
Has thanked: 740 times
Been thanked: 2355 times
have you thought about a naked one to go with your battery kit
i got a 18v dewalt for £60 :wink:
OnlineOnline
Has thanked: 1012 times
Been thanked: 918 times
Post by ultimatehandyman »
I have the 18 volt dewalt one as well and it is very handy
Hitch
Has thanked: 77 times
Been thanked: 335 times
Post by Hitch »
Hes not likely to buy a top notch one is he....?
http://www.lawson-his.co.uk/scripts/pro ... TADA4000LR
The middle one.
I will reccomend that bad boy. :thumbright:
Plenty of power for the big holesaws, and the end will rotate :thumbright:
Cannyfixit
big-all wrote:have you thought about a naked one to go with your battery kit
My Dewalt battery drill is 14.4 however i do have a Ryobi 18volt battery drill is there a angle drill made by Ryobi,i have looked on the Ryobi web site and nothings listed
http://www.ryobi-direct.com/acatalog/index.html
sparkydude
Has thanked: 2 times
Been thanked: 149 times
Post by sparkydude »
yes they do make one , looked on google and came up with this one, there was quite a few listed but heres the one i found.
http://www.newpowertool.co.uk/ryobi-18v ... 2113-p.asp
Nick
Cannyfixit
Excellent Sparkdude :thumbright: i know im harping on now but would a battery drill take the load of several 2/3" holes through hardwood carcases :scratch:
sparkydude
depends how many batteries you have to do the job. Honestly if i was doing it as a job a mians one would have to be a must .
especially if the boss is buying it go for a decent one, he wont have to pay the vat anyways .
Nick
Wood Magnet
Been thanked: 3 times
Post by Wood Magnet »
I agree with Nick, use a mains drill. :thumbright:
People forget how fast you did a job - but they remember how well you did it.
I no longer skinny dip, i chunky dunk these day's.
Hitch
Post by Hitch »
3" holesaws will kill batteries pretty sharpish.
A nice 110 one :thumbright:
Cannyfixit wrote:Excellent Sparkdude :thumbright: i know im harping on now but would a battery drill take the load of several 2/3" holes through hardwood carcases :scratch:
ok 3" holes in hardwood may be pushing it a bit i will try my dewalt with a 3" in 20mm pine later as i dont have a bit of 3" hardwood handy :scratch: :scratch:
OnlineOnline
tried the dewalt worked fine on a 20mmx76mm hole in close grain quite hard redwood
drilled 3 holes on a battery thats been lying around uncharged for several weeks did warm up a bit but not to bad
wouldnt fancy 6 holes in harder wood without a breather after the third to cool down though
OnlineOnline
Cannyfixit
Much appreciated guys,looks like 110 volt is the way to go,now i can go back to my boss and he will think i'm dead clever :lol: l
Hitch
Post by Hitch »
Try and get that Makita out of him :wink:
Return to “Tool Talk”
