Right angle drills
Posted: Sat Dec 15, 2007 8:46 pm
by Cannyfixit
Im in negotiatiation with my boss as to why he needs to buy me a right angle drill,my job is fitting Beer lines behind the bar and i have to drill combinations of 1" 2" 3" holes using hole cutters,as some of you may appreciate getting access to the back of the bar is a right pain in the butt hence the need for a angle drill.
So if i was to drill half a dozen 3" holes what angle drill would be the best buy looking for something that wouldnt burn out after a few uses as this will be a one off purchace the boss is a tight arse
Oh and it needs to be 110 volt
Posted: Sat Dec 15, 2007 8:55 pm
by big-all
have you thought about a naked one to go with your battery kit
i got a 18v dewalt for £60
Posted: Sat Dec 15, 2007 9:13 pm
by ultimatehandyman
I have the 18 volt dewalt one as well and it is very handy
Posted: Sat Dec 15, 2007 9:23 pm
by Hitch
Hes not likely to buy a top notch one is he....?
http://www.lawson-his.co.uk/scripts/pro ... TADA4000LR
The middle one.
I will reccomend that bad boy.
Plenty of power for the big holesaws, and the end will rotate
Posted: Sat Dec 15, 2007 10:49 pm
by Cannyfixit
big-all wrote:have you thought about a naked one to go with your battery kit
My Dewalt battery drill is 14.4 however i do have a Ryobi 18volt battery drill is there a angle drill made by Ryobi,i have looked on the Ryobi web site and nothings listed
http://www.ryobi-direct.com/acatalog/index.html
Posted: Sat Dec 15, 2007 10:50 pm
by sparkydude
yes they do make one , looked on google and came up with this one, there was quite a few listed but heres the one i found.
http://www.newpowertool.co.uk/ryobi-18v ... 2113-p.asp
Nick
Posted: Sat Dec 15, 2007 10:53 pm
by Cannyfixit
Excellent Sparkdude
i know im harping on now but would a battery drill take the load of several 2/3" holes through hardwood carcases
Posted: Sat Dec 15, 2007 11:09 pm
by sparkydude
depends how many batteries you have to do the job. Honestly if i was doing it as a job a mians one would have to be a must .
especially if the boss is buying it go for a decent one, he wont have to pay the vat anyways .
Nick
Posted: Sun Dec 16, 2007 12:18 am
by Wood Magnet
I agree with Nick, use a mains drill.
Posted: Sun Dec 16, 2007 12:21 am
by Hitch
3" holesaws will kill batteries pretty sharpish.
A nice 110 one
Posted: Sun Dec 16, 2007 11:06 am
by big-all
Cannyfixit wrote:Excellent Sparkdude
ok 3" holes in hardwood may be pushing it a bit i will try my dewalt with a 3" in 20mm pine later as i dont have a bit of 3" hardwood handy
Posted: Sun Dec 16, 2007 3:21 pm
by big-all
tried the dewalt worked fine on a 20mmx76mm hole in close grain quite hard redwood
drilled 3 holes on a battery thats been lying around uncharged for several weeks did warm up a bit but not to bad
wouldnt fancy 6 holes in harder wood without a breather after the third to cool down though
Posted: Sun Dec 16, 2007 7:51 pm
by Cannyfixit
Much appreciated guys,looks like 110 volt is the way to go,now i can go back to my boss and he will think i'm dead clever
l
Posted: Sun Dec 16, 2007 7:54 pm
by Hitch
Try and get that Makita out of him
