HELP Dishwasher Vs Plinth
- Has thanked: 7 times
Hi, I have just had an intergrated dishwasher installed but the plinth underneath has now been cut to accommodate the front door to the dishwasher when it is opened. This means when it is closed up there is a massive big black hole in the plinth which looks ugly.
As I have enough plinth to start again could anybody advise me on how to overcome this issue Please
- Has thanked: 39 times
- Been thanked: 621 times
Re: HELP Dishwasher Vs Plinth
The plinth will be correct. It needs to reduce down in height for the door to open and close.
- Colour Republic
- Has thanked: 263 times
- Been thanked: 544 times
Can you post a picture?
The plinth needs cutting down to allow the door to open but I'm wondering if somebody got a bit saw happy and trimmed more than needed.
They need trimming down from anything between 5mm and 30mm depending on the dishwasher / kitchen
Just under the dishwasher. That is normally 20mm lower than the rest of the plinth.
Suck it and see as it may be 15mm. So make it 15 less and see if it is clear of the door when opened.
- Colour Republic
No just under the dishwasher.
Fit the kicker board untrimmed, open dishwasher and see where it hits, mark it and then trim 3 or 4 mm below this
When the door is down it fits snug into the space that's been cut into the plinth so I imagine that can't be reduced. It just looks so bad especially as its facing you when you enter the kitchen!
Is there no other way ie height of dishwasher etc?
Ill post a picture soon
Regards
Regards
- Has thanked: 104 times
- Been thanked: 490 times
Usually it is hardly visible, but may depend on how far away you are standing - I've attached a couple of examples.
- ayjay
- Has thanked: 458 times
- Been thanked: 1708 times
It could be that it needs jacking up higher, some of the leg mechanisms on these things are on the fragile side, possibly the fitting has become knackered it and won't work. Is there a gap over the top of the dishwasher? (between the dishwasher and the underside of w/top)Boycee73 wrote: Is there no other way ie height of dishwasher etc?
Is the dishwasher right back to the wall, or is there an obstruction behind it?
Well here are my photo's
As you can see UGLY!!!!
There appears to be more cut that necessary when the door is down but I've included the top of the dishwasher showing the distance from the top of the dishwasher to the worktop. Also when I took these I've now noticed the cut isn't the straightest.
Any solutions??
Kind regards
Any solutions??
Kind regards
- plintyh3b.jpg (73.28 KiB) Viewed 23202 times
- plinth 3a.jpg (111.13 KiB) Viewed 23202 times
- plinth 2a.jpg (88.44 KiB) Viewed 23202 times
- plinth 1 .jpg (168.98 KiB) Viewed 23202 times
Surely they've fitted the dishwasher wrong - they are usually tight up against the worktop with no gap at the top - what make / model is it?
- Has thanked: 4 times
- Been thanked: 49 times
Where did the kitchen come from? Cos if its a Wickes or Benchmarx kitchen then due to the height of e fascias then the dishwasher does need to sit lower but only 15mm that looks to be 40 odd! But it is usual to reduce the plinth by 15mm under the dishwasher so the door will open fully, I admit its not e very clean cut and it doesn't look like its been re edged either.
IF IT WERE EASY ITD B BORING!
I think from what I you guys are telling me is that the dishwasher is set to low which when adjusted up will allow the cut into the plinth to be less...i think??
