Installing toilet directly on top of porcelain floor tile
Posted: Wed Apr 17, 2013 8:35 am
by gocsan
Morning all
I'm about to tile my bathroom floor with porcelain tile with the toilet removed beforehand. Just thinking ahead, do I need to put some kind of putty, or any rubber material in between the tiled floor and the toilet to act as a cushion? Or can I just put the toilet directly on top of the tile and screw it on?
Many thanks
Re: Installing toilet directly on top of porcelain floor til
Posted: Wed Apr 17, 2013 12:47 pm
by wine~o
You could bed it down on a bead of silicone. Hope you've got the necessary to drill through the porcelain tiles...
Posted: Wed Apr 17, 2013 12:54 pm
by BillyGoat
wine~o wrote:You could bed it down on a bead of silicone. Hope you've got the necessary to drill through the porcelain tiles...
Hammer?
Posted: Wed Apr 17, 2013 3:45 pm
by wine~o
Hammer off...
Posted: Thu Apr 18, 2013 7:15 pm
by royaloakcarpentry
Just sit the krapper on the floor and mark out for screw positions. Armeg porcelain drill bits are extremely good and will only set you back about £25 for an 8mm bit.
Don't sit the krapper on silicone as you will be left with a right pig of a job should you need to move it out because of a leak etc etc.
You want stainless steel or brass screws.
