Drilling Through Tiles
luki
Post by luki »
Hello All,
First I am really sorry if this question has been asked already….But I have finished tiling the whole bathroom, just finished the dreaded grouting….Now I need to drill through the tiles, there has to be an easier way I am struggling in trying to break the glaze…. ::b
Thanks for all your help.
Luki…x
tim'll fix it
Been thanked: 1 time
Post by tim'll fix it »
what type of drill bit are you using
what are the tiles made of ceramic or porcelain
are you wetting the drill bit to keep it cool
I use a tile drill bit the pointed type, the ones from B&Q are fine. Use it in a corded power drill as they have more torque than a battery drill and hold a wet sponge against the drill bit to keep it cooled.
You can use a bit of masking tape on the tile to stop it slipping at first.
I have used this technique to drill both cermic and porcelain. Porcelain is very tough though and can take a 1/2 hour to drill a single hole. You could always consider siliconing what ever it is you want to fix up
Has thanked: 1012 times
Been thanked: 918 times
Post by ultimatehandyman »
luki
Post by luki »
Thank you very much....
They are ceramic tiles, and the link has helped, I need to get a new drill bit....Will post tomorrow, to let you know how I get on....
Thank you so much.....
Luki x :-)
Mudster
Tiling Expert
Post by Mudster »
I always used a centre punch and a light hammer, I found even with the steadiest hand the drill would slip slightly on tape.
farkendr
Post by farkendr »
Hi Mudster.
Top solution as ever
Is that a specialized centre punch, or just any off the shelf item.
Cheers : :-)
panlid
Post by panlid »
dont press on to hard when starting the drill. hold the drill so the bit is hardly touching the tile and in a few seconds you will have a start.
bathstyle
Post by bathstyle »
I just break the glaze with the point of a screw and a hammer, try it next time.
panlid
Post by panlid »
trust a plumber to be too tight to buy a dot punch :lol:
bathstyle
Post by bathstyle »
Do people actually use masking tape to stop the drill bit wandering? I thought it was just a token answer for DIY manuals.
panlid
Post by panlid »
does it work? :?
bathstyle wrote:Do people actually use masking tape to stop the drill bit wandering? I thought it was just a token answer for DIY manuals.
I have used masking tape in the past when using masonry bits on ceramic tiles, it does work and helps to get the drill started :wink:
Spear shaped bits are much better though!
panlid
Post by panlid »
im trying one of these at the moment. cost £20 for an 8mm drill and you get a masonry bit also.
so far ive drilled 4 holes in 10mm thick porcelain and i have 5 more to drill tomorrow. will let you know what they are like.
http://www.armeg.com/tile-ptc.php
bathstyle
Post by bathstyle »
That'll be the Armeg then?
I spent a few years using these bits, I found them overpriced and unable to cope with dense Porcelain, I'm suprised Armeg can market them aimed at the Porcelain market
panlid
Post by panlid »
if i buy a cheap diamond tipped 8mm holsaw for about 4 quid and get 3 holes out of then i want at least 15 holes out of this. they say it is a new bit?
13 holes to go :wink:
Return to “Tiling Forum”
