Plumbing and Kitchen Units
Posted: Mon Jul 07, 2014 9:08 pm
by jaydebruyne
I just wanted to ask you kitchen fitters a question:
I'm getting into plumbing and wanted to know, when plumbing has been concealed behind or within kitchen units and access is impossible, what options are? Dismantle the units to get access?
I need to look at a tap which has been boxed in because of the kitchen units and currently there is no way for me to get any type of tool to the tap backnut.
Many thanks in advance for any help you can give.
Re: Plumbing and Kitchen Units
Posted: Mon Jul 07, 2014 9:12 pm
by philprime
I'd say sloppy fitting in the first place
If you can't get any tools to it you don't have much choice than remove the cabinet
Posted: Mon Jul 07, 2014 9:20 pm
by jaydebruyne
philprime wrote:I'd say sloppy fitting in the first place
That's what I feared.. And that's quite difficult to do isn't it? Don't you have to remove the worktop first?
Posted: Mon Jul 07, 2014 9:27 pm
by philprime
You will find that most kitchen units are screwed in to the worktop from the inside of the cabinet, a good fitter will also screw the cabinets together I always put my fixings behind the hinges
Once you have removed the screws take the kick board off and wind the legs down and you will be able to slide the cabinet out
Posted: Mon Jul 07, 2014 9:42 pm
by jaydebruyne
philprime wrote:You will find that most kitchen units are screwed in to the worktop from the inside of the cabinet, a good fitter will also screw the cabinets together I always put my fixings behind the hinges
I'm hoping when I go to have a look they'll be a simpler solution. I'll find out Thursday morning :/ But thanks so much for the info, it's a big help ;)
Posted: Mon Jul 07, 2014 9:45 pm
by philprime
You may find there is an easier option good luck on Thursday
Posted: Mon Jul 07, 2014 10:56 pm
by joinerjohn
Posted: Mon Jul 07, 2014 10:58 pm
by jaydebruyne
Wow, you have to admire the art in his work :P
Posted: Tue Jul 08, 2014 6:06 am
by speed
just hope the cab is not screwed to the wall or worse.... screwed to the next cabs on each side in the service void,(like i do)
you could look se if it had a removable back, or smash that back out and fit a new removable access panel/back
Posted: Tue Jul 08, 2014 6:26 am
by jaydebruyne
speed wrote:just hope the cab is not screwed to the wall or worse.... screwed to the next cabs on each side in the service void,(like i do)
What I don't want to do is remove a piece of wood and the units come crashing down! Dramatic I know but it's my first plumbing job so I want to do it right.
Posted: Sat Jul 12, 2014 2:41 pm
by fin
worst case. and if ya know what make of kitchen it is price for a replacement unit incase you have to knacker the old one to get to the tap nut.
seems strange you cant get to the tap nuts like.
Posted: Sat Jul 12, 2014 3:32 pm
by jaydebruyne
fin wrote:worst case. and if ya know what make of kitchen it is price for a replacement unit incase you have to knacker the old one to get to the tap nut.
I've done the job now. I was able to get to the backnut, but it took a while to get it off. It was housed behind a sheet of 18mm marine ply which had barely been made accessible.
Mole grips and patience and the nut was off ;)
Posted: Sat Jul 12, 2014 4:16 pm
by fin
ahh well nice one.
