Plastering over and around a new new plug socket
- Andrew
- Has thanked: 3 times
- Been thanked: 3 times
I've got a small section of wall which has had a blown piece of plaster removed so now it's only brickwork. Luckily it's just over where the skirting would be, and so I have chiselled out a space for a double plug socket and channelled a space below for the wires to go.
It is best practice to just plaster over the wires? I'm not talking about safety here, but just what is normally done. Do people use conduit for this, or should I just shut up and slap bonding over it? I like being neat and tidy, but I don't know if this is going too far.
Thanks very much.
Thanks very much.
- ultimatehandyman
- Site Admin
- Has thanked: 1012 times
- Been thanked: 918 times
Plastic capping is normally used to protect the wires from the plasterers tools, it is nailed over the wires and held in place by nailing into the mortar between the bricks.
Many people do not use capping, just ensure you do not damage the cables with your trowel when plastering.
Use bonding plaster to fill most of the chase and then finish it off with finish plaster.
- Noname.jpg (3.56 KiB) Viewed 5635 times
- ultimatehandyman
- Site Admin
- Deceased 21-10-2011 R.I.P
- Has thanked: 8 times
- Been thanked: 90 times
If it's only a short run, you don't need capping. The only real use for capping is to hold the cables down to the wall. You'd have to be pretty ham fisted to damage the cable sheath with a plastering float. On a short run, the judicious use of a galv nail with a big head will also hold the cable down. Or a pair of cables on a ring.
- ultimatehandyman
- Site Admin
