Clamping a Worktop
- Argyll
- Has thanked: 1189 times
- Been thanked: 583 times
Clamping a Worktop
I was told never to use pressure clamps when I mitre a worktop. I was told they don't hold the jig tight enough and to always use G clamps. Thoughts?
- steviejoiner74
- Has thanked: 747 times
- Been thanked: 1616 times
Re: Clamping a Worktop
I've always used speed clamps,decent ones tho and never ever had a problem.
- Has thanked: 81 times
- Been thanked: 48 times
I would have thought a set of Irwin quick grips would be just as good if not better. I bought a set a few years ago, the more powerful version and since then I have bought a lot more of different sizes - they have been invaluable in all different bits of work. My old man was sceptical when I first bought them but was amazed by them.
I haven't used them for a worktop but a lot of other things.
- Colour Republic
- Has thanked: 263 times
- Been thanked: 544 times
irwin quick grips for me.
But 1 type is suitable, the other isn't. I'm assuming you'll be able to tell which is which...
- Has thanked: 32 times
- Been thanked: 808 times
this is what i use
though i did some worktops the other night and used some smaller clamps that are exactly the same just smaller. i picked em up for £3.50 for a pair from screwfix. they worked fine. probably better due to not getting in the way
- ayjay
- Has thanked: 458 times
- Been thanked: 1708 times
They may be good enough, but they're not going to be better (as far as clamping ability goes) I'd trust my life to my old 8" Record G-cramps - have done in fact, I wouldn't do that with a plastic cramp.afmfifgh wrote:I would have thought a set of Irwin quick grips would be just as good if not better. .
@ fin - those are *F* clamps.
biiiiiiiig F clamps.
ive had sliding ones before but eventually they stop clamping.
trouble with my trend ones is the red plastic parts keep coming off.
- Colour Republic
I promise you Ayjay those quick clamps (the blue and silver not the blue and yellow) are more than man enough to hold a jig in place without fear of it moving even a knats armpit despite whacking the jig by accident.ayjay wrote:They may be good enough, but they're not going to be better (as far as clamping ability goes)afmfifgh wrote:I would have thought a set of Irwin quick grips would be just as good if not better. .
Irwin do 3 different types, the common ones, blue and yellow which have 150bls of force, blue and blue 300lbs of force and the blue silver at 600lbs of force.
If I thought manual G clamps where more suited I'd use them. Not saying g clamps are unsuitable as I'm sure thousands of chippies still use them in the above scenario, but not all quick clamps are created equal, some are very well suited and have a few minor added benefits over g clamps
- steviejoiner74
- ayjay
I don't doubt that they'll do the job, (I even said as much), but I still maintain that a decent pair of G-cramps have more power than a plastic pair.Colour Republic wrote:I promise you Ayjay those quick clamps (the blue and silver not the blue and yellow) are more than man enough to hold a jig in place without fear of it moving even a knats armpit despite whacking the jig by accident.ayjay wrote:They may be good enough, but they're not going to be better (as far as clamping ability goes)afmfifgh wrote:I would have thought a set of Irwin quick grips would be just as good if not better. .
........................and, I just searched google - 8" Record G-cramps = 1809kg of clamping force - I rest my arse.
- Argyll
I have no idea mate. Enlighten me.Colour Republic wrote:irwin quick grips for me.
But 1 type is suitable, the other isn't. I'm assuming you'll be able to tell which is which...![]()
