End panels, wall and base, same as cabinet doors?
manny
Has thanked: 63 times
Post by manny »
Hello, I ordered a white gloss kitchen, however the wall and base end panels did not have the same finish as the doors.
I'm sure the end panels should be like the doors. So basically the same material and finish.
I'm not happy with the ones they gave me.
I assumed they would have been the same as the doors but this wasn't the case.
I wasn't told otherwise by the kitchen company either neither did I query it initially.
Rorschach
Has thanked: 120 times
Been thanked: 1043 times
Re: End panels, wall and base, same as cabinet doors?
Post by Rorschach »
Usually this is an extra order item, you only order matching side panels for the areas that will be seen.
Maz123
Has thanked: 19 times
Been thanked: 23 times
Post by Maz123 »
Yes the end panels should be the same colour and finish as the doors. They should match.
If they aren't already fitted I'd send them back.
These users thanked the author Maz123 for the post:
manny
manny
Post by manny »
Rorschach wrote:Usually this is an extra order item, you only order matching side panels for the areas that will be seen.
Yes that's correct. The end panels were extra items that were included with my kitchen. And priced in accordingly.
manny
Post by manny »
Maz123 wrote:Yes the end panels should be the same colour and finish as the doors. They should match.
I rang the kitchen company today and explained the panels were not what I expected. So I will be returning them.
Rorschach
Post by Rorschach »
Oh I'm sorry, I mis-read your original post, I thought they weren't ordered.
manny
Post by manny »
No worries.
Return to “Kitchen Fitting”
