- Ultimate Handyman Forum Index Other DIY Computers communications and broadband
- It is currently Mon Mar 31, 2025 4:06 pm
Strange colours in telephone extension
Telecommunications, Broadband and networking questions in this forum please
- Has thanked: 1 time
Post by artzybashev »
Hi everyone,
I have a telephone extension which I am wanting to fix directly into the master socket but on stripping back the wires I discover some unusual colours and some different colour tails attached (see photo). The wires are all solid, blue, red, orange and white. The tails attached are yellow onto blue, green onto orange, red on red and black onto white. As green, red, black and yellow are the old four strand colours, I presume the tails are attached here to indicate the colour they are intended to represent.
Following the colour equivalent chart (see attached also) I have wired the connection as follows: orange (with green tail) in number 5 which would be white / blue dash in new colour
blue (with yellow tail) in number 3 which would be orange / white dash in new colour
red (with red tail) in number 2 which would be blue / white dash in new colour
The extension is completely dead. Where have I gone wrong in this process? Have I misunderstood these colour equivalents?
Before dismantling the extension it was working fine when plugged in as a socket.
Any help would be greatly appreciated. Thanks.
artzybashev
- kellys_eye
- Has thanked: 357 times
- Been thanked: 1790 times
Re: Strange colours in telephone extension
Post by kellys_eye »
Why the 'direct' connection? A simple line splitter would save the hassle and make it removable (if required).
Most phone sockets use pins 2 & 6 for the line.
kellys_eye
- Someone-Else
- Has thanked: 48 times
- Been thanked: 2604 times
sorry its 2 & 5.
But yes, why not buy a whole new socket, easier, and less hassle
Thanks for the quick replies. The reason I wanted to wire this in is because I already have a line plugged in the socket and since the option exists to wire a second line inside the box, it is tidier than a splitter hanging off the front. The extension line is buried through the house and not easy to replace with a new one. Now the wires have been stripped back I either need to wire it into the box or fit a new plug and use a splitter. Either way, I need to figure out how these colours should go. Do you think the coloured tails are meant to indicate old colours? I know 3 is just the old ringer wire but it does no harm to fit it. 2 & 5 should be working though. Could try some trial and error I suppose.
artzybashev
- kellys_eye
kellys_eye
- camallison
- Has thanked: 127 times
- Been thanked: 108 times
Post by camallison »
Far-Eastern manufacturers of such cables/sockets quite often just put in whatever colours they fancy and so it might be best to ring out the pins in the socket to the cable ends. I have seen this many times and been caught out by it like you. A simple multimeter check on the ohms range should suffice (if you have a multimeter, of course!).
Colin
Colin
camallison
Hi,camallison wrote:Far-Eastern manufacturers of such cables/sockets quite often just put in whatever colours they fancy and so it might be best to ring out the pins in the socket to the cable ends. I have seen this many times and been caught out by it like you. A simple multimeter check on the ohms range should suffice (if you have a multimeter, of course!).
Colin
Thanks for all the replies. I think you are right about the random wiring. I have sorted it now. The answer was a follows.
2 white
3 red
5 blue
should have ignored the colours and followed their positions in the discarded plug socket in the photo. Over-complicated the whole process for myself.
Thanks everyone.
artzybashev
Return to “communications and broadband”
